MoC's Build Thread - Page 110 - JeepForum.com
 3Likes
post #1636 of 2044 Old 03-19-2013, 08:26 PM Thread Starter
MoC
One thought I had....
They plugged the passages from the alt. compensator in to the carb base. Maybe they cracked the base when they installed them and it opens up when in my base plate and not on theirs.
MoC is offline
post #1637 of 2044 Old 03-19-2013, 08:45 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If National Carb can't figure it out, then I doubt any of us stand a chance, either.
Doesn't the 2100 come in the venturi size you need?
Matt
Matt1981CJ7 is offline
post #1638 of 2044 Old 03-19-2013, 08:52 PM Thread Starter
MoC
Matt
It does but i want to try to find a 2150 first so that I have all the right vac connections in the correct locations.
MoC is offline
post #1639 of 2044 Old 03-19-2013, 08:55 PM
ASteve
1972 CJ5
MoC,
You can have my 2150. It's a 1.08 though. Has a slight leak when you wiggle the throttle at the base plate. Other than that it's in great condition.
It's yours if you want to mess with it.
SC
ASteve is offline
post #1640 of 2044 Old 03-19-2013, 08:56 PM
Matt1981CJ7
1981 CJ7
Vac connections...pfffftt...you can always make them work.
Matt
post #1641 of 2044 Old 03-19-2013, 10:31 PM Thread Starter
MoC
Originally Posted by ASteve View Post
MoC,
SC
I really appreciate the offer Steve it is very generous. I have 2 other 2100 1.08's to play with if needed.
Matt
Matt I guess I am just stubborn and strong willed. I want my engine to run with the stock carb & stock gaskets because it should. I really pizzes me off that it doesn't now and I must win.
I did have a nice score tonight. I was hanging out at my good friend and jeep buddy's house and raided his collection and scored some free parts.
Walked away with a old style metal spacer plate from a 71 304.
Also got a AMC 2100 1.21 with all the right pieces in all the right locations.
[IMG][/IMG]
[IMG][/IMG]
It would be the perfect carb to send to National to have them rebuild but....
[IMG][/IMG]
The ear cracked and it was jb welded over. If I send it to National I am sure the ear will break off when the tumble it to clean it.
The good news is I saw it running on a 304 about 5 years ago so I should be able to bolt it on and go until I get something resolved with the other carb.
So the plan is to install this carb on the 360 and move on adjusting the clutch out and actually driving this more than 30 feet at a crawl.
Should hear back from National tomorrow and find out if they have a 2150 AMC core. If they do they are going to rebuild it and see if it runs on the AMC spacers. If not I will be hunting one down to get to them.
Hoping to have time Saturday to install the newest carb.
MoC is offline
post #1642 of 2044 Old 03-19-2013, 10:58 PM
rixcj
rixcj's Avatar
1979 CJ5
MoC...I have an MC2150 that came on my '89 360. I had it completely cleaned and rebuilt, but never installed it. The float( also brand new...) might have to be set, though. I was hanging onto it, in case I ever needed it. I run a Holley 600 on My 360, so, I'll probably never use the 2150. I would think that the one that I have could just be installed, without sending it to National Carb...I'm sure we could work something out, if you're interested...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #1643 of 2044 Old 03-20-2013, 06:30 AM Thread Starter
MoC
Rich
PM send Rich!
MoC is offline
post #1644 of 2044 Old 03-23-2013, 02:45 PM Thread Starter
MoC
Nothing really happening around here. National has no clue what is wrong with the carb and are looking for another core to build. It could take a bit of time.
Rich has a 2150 heading my way that will be here Monday. It's clean and rebuilt. Plans are to double check float level and choke settings, clean on it a little more and then roll with it.
If national finds a core I will just stick it on the self for future use. If they can't find one I am going to send the 1.08 2100 that will eventually find its way on the Laredo to them to build.
Installed my mirrors today and a set of courtesy lights I had.
Once the carb is on and dialed in my list is very short.
Install front axle and tcase vents
Tighten e brake back up
Adjust the clutch
Run by Minekee for a little adjustment on the pipes
Work the last little bit of air out the power steering
After that this engine swap is done.
I do have 1 confirmed oil leak. I have a drop on the bottom of one of the oil pump bolts. Think I will wait to tackle that when I do the next oil change as long as it doesn't get big.
MoC is offline
post #1645 of 2044 Old 03-26-2013, 02:04 AM
gazzo
Originally Posted by MoC View Post
Its their, just hard to follow. The green is the return and the red is the fuel line.
Hi MoC. I'm trying to work out the correct mounting for the alternator on my POS 360. I reckon I'm missing some crucial part/bracket. I've tried to see what's up on your engine but I just can't get to where I can see what I need. Would you mind teribly snapping some up close shots around that area so I can see what I need to make or buy please? Would be an enormous help.
Thank you Sir.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #1646 of 2044 Old 03-26-2013, 02:15 AM
Matt1981CJ7
1981 CJ7
Gary,
If you can't find the right bracket, Bultear makes a pricey but nice one, but their customer service leaves a lot to be desired.
I think you could fab one that's similar, pretty easily.
Matt
post #1647 of 2044 Old 03-26-2013, 02:32 AM
gazzo
Gary,
Matt
Thanks Matt I just joined and bid on one on eBay. 50 bucks. There a big funky shaped bracket as well as the sliding adjuster one. The set up in your pictures looks similar to the way this one is/was only mine looks nicer
My whole engine looks almost pretty as yours and MoCs if you squint.
Gary (gazzo)
gazzo is offline
post #1648 of 2044 Old 03-26-2013, 08:23 PM Thread Starter
MoC
Hey Gary!
My 360 came with a/c so my brackets will different than if you have a non ac 360. On the a/c 360's the compressor shares a alt bracket. Here is what I have on the computer. If you need come closer let me know!
Got Rich's carb in the mail yesterday. I had a few minutes yesterday and today, got it installed and she is running like a champ as of this afternoon. Still have a short list and have not driven it yet. Likely will be Saturday before I have the time to get it on the road for the first time. Other than the oil leak I already knew about I found a ps leak at the pump connection today. Hope thats all the leaks buy Mr. Murphy likely has more in store for me.
Also talked to National today. The found another core and are building it. I am planing on swapping the National carb on when it comes just because its prettier and shinier.
Will post of a good video of her running this weekend.
MoC is offline
post #1649 of 2044 Old 03-26-2013, 10:58 PM
rixcj
rixcj's Avatar
1979 CJ5
I'll tell you....having a jeep that doesn't leak is damn near impossible. I have changed out just about every seal and gasket that was ever leaking on my jeep, and then some. I recall that it DIDN'T leak for about a week. YAY!!
Well, that didn't last long...! So now, it has a couple of weep areas....and, for now, at least...they're gonna remain that way.
Rich
rixcj is offline
post #1650 of 2044 Old 03-27-2013, 09:36 AM
wm69
Dad's Scrambler was seeping from the valve cover the day he brought it home from the dealership.
When I first bought my Jeep I stopped in a shop and the guy there said "if a Jeep isn't leaking it means it's out of fluid"
wm69 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
