MoC's Build Thread - Page 108 - JeepForum.com
 3Likes
post #1606 of 2044 Old 03-12-2013, 12:46 PM
CJ7ROB
Your better off with the Edelbrock 4bbl if you do decide to switch..Q-Jets have at times been known as Quadra-Junk.
CJ7ROB is offline
post #1607 of 2044 Old 03-12-2013, 12:58 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I guess that's why the Q-jet was produced for over 40 years, and it's widely considered GM's most popular carburetor.
Every carb has a derogatory nickname, usually given to them by someone who didn't know how to work on them.
Matt
Matt1981CJ7 is offline
post #1608 of 2044 Old 03-12-2013, 01:08 PM Thread Starter
MoC
Originally Posted by ASteve View Post
MoC,
Like this?
Yes sir, that looks like it.
MoC is offline
post #1609 of 2044 Old 03-12-2013, 01:08 PM
ASteve
1972 CJ5
Matt,
Not to gang up on CJ7Rob, but I really can't stand someone saying something is junk without backing it up with factual information. Like you said, "every carb has a derogatory nickname, usually give to them by someone who didn't know how to work on them".
SC
ASteve is offline
post #1610 of 2044 Old 03-12-2013, 01:11 PM
ASteve
1972 CJ5
This one is warped a little but could be machined or sanded down to be flat again. Do you need it. I've seen them around here and there for $50.00, but for you MoC it's free!
Here's another shot:
SC
ASteve is offline
post #1611 of 2044 Old 03-12-2013, 01:31 PM
CJ7ROB
Matt,
Not to gang up on CJ7Rob, but I really can't stand someone saying something is junk without backing it up with factual experiences. Like you said, "every carb has a derogatory nickname, usually give to them by someone who didn't know how to work on them".
SC
Had one on my Camaro & Olds, had different issues with them even after being professionally rebuilt. Like you say maybe it was the rebuilder or because they had been pretty old. Switched to new Edelbrock Performer 600cfm (#1406) on the Camaro with good results. There are lots of choices for carbs out there and your right they all probably have received a derogatory name at sometime.
CJ7ROB is offline
post #1612 of 2044 Old 03-12-2013, 05:56 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I would honestly love to run a Quadra-flog if I knew how to set them up right. I hear that is the biggest issue, they are a pain to fine tune.
Rick
Cutlass327 is offline
post #1613 of 2044 Old 03-12-2013, 07:26 PM Thread Starter
MoC
SC
Thanks so much Steve, that is a really generous offer and I appreciate it!!!
I will let you know if end up needing it, still have hope that I will be staying with the 2150.
MoC is offline
post #1614 of 2044 Old 03-12-2013, 08:12 PM
Skerr
Sure have. BTW you can tell the differance between the Ford 2100 and the AMC 2100 by the bases. The Fords have a 1/2 moon shape on the back side and the AMC's are square.
Also in your picture... The green is a manifold vac source however it was not factory for the dizzy vac advance. The factory advance was ported not manifold. The green on that carb was origanlly a manifold vac source for the choke pull off. The one in the top of your picture on the "disk" was one of the choke tube connections, the capped on with a black plug on the side by the choke was ported for the canister purge, and the one by the mixture screews was the ported for the dizzy. The little hole below the two yellow circles that is recessed in the Pocket area is where the power valve pulls its manifold vac through. Some of the newer 2150's, dont remember the year break, dont have that little hole but have a nipple on the cover that has to be connected to a manifold vac source.
Let me know if you want more info
BTW, Just messing with you Scotty!
Well he was asking for it Bill.
Love you Scott! BTW you didn't call back today. ..... and I thought we were friends....
I didn't call because I had to work. Probably be Thursday before I have the chance. I have a job interview Thursday morning, and then swap out Clay's gear box, then work again from 5-9 at AZ. I MAY be able to fit you in!
Originally Posted by lucdog View Post
Great MoC, now he won't be "right" for weeks.
Bill
More truth than fiction in that statement, Bill!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1615 of 2044 Old 03-12-2013, 10:43 PM Thread Starter
MoC
Man Scott and I thought I was busy!! Good luck on the interview and talk to you when soon!
MoC is offline
post #1616 of 2044 Old 03-13-2013, 05:57 AM
Skerr
Interview tomorrow morning, and another one Friday morning. Either job should be MUCH better than what I'm doing now. Keep me in your thoughts, please.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1617 of 2044 Old 03-13-2013, 06:03 AM
WNC-84CJ7
Right on bro. Call or text me this weekend, let me know how it goes. I was thinking about getting a job myself...
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #1618 of 2044 Old 03-13-2013, 06:32 AM
gazzo
Good luck Scott. Own it.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #1619 of 2044 Old 03-13-2013, 06:57 AM
rixcj
rixcj's Avatar
1979 CJ5
Good luck with the interview, Scott! Show them your jeep thread and they'll hire you for sure! Tenacity like that is hard to come by, these days!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #1620 of 2044 Old 03-13-2013, 07:04 AM
roboto65
1976 CJ5
Good Luck with the interview Scott
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
