MoC's Build Thread - Page 105 - JeepForum.com
 3Likes
post #1561 of 2044 Old 03-08-2013, 11:20 AM
rixcj
rixcj's Avatar
1979 CJ5
Boy, oh boy...the weather's a lot nicer there than here...it's snowing the wind's howlin' .
Bet you're dying to hear how it sounds. Good luck with the carb!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #1562 of 2044 Old 03-08-2013, 12:03 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hey Moc,
Exhaust day is an exciting one.
Regarding your carb problems. I recall reading there may be differences in the bases of the 2100 and 2150. I'll bet the 2150 requires a different adapter plate, or gasket, than the 2100.
Like you, I'd be very surprised if there's a problem with the National carb.
Have fun, today....
Matt
Matt1981CJ7 is online now
post #1563 of 2044 Old 03-08-2013, 01:35 PM Thread Starter
MoC
Rich
68 and partly cloudly today! I think were were 39 for the low last night. The rains coming sunday and bring back some cold with it.
Originally Posted by Matt1981CJ7 View Post
Hey Moc,
Have fun, today....
Matt
You are correct Matt, the gaskets are different. The gaskets I bought are specific to a 2150.
I am pretty stumped on the carb. Torn in to it yesterday and everything looks great. Everything is clean, check ball it their, no debris under the needle, float does not appear to be hanging, power valve is not bad from my one backfire when I was 180 out. I talked on and off with National as well hunting for ideas. I did notice the clip that holds the needle to the float was missing. Thinking I had found my smoking gun I called National and the said they intentionally leave it off on thier rebuild as one of the "Tweeks" they do.
My plans are to blow everything out with carb cleaner, replace the power valve (even though I am 100% sure its good), install the missing clip they left off, dry check the float level, then button her back up and see what happens. If it is still not running I am going to pull the top and see where I am at with fuel in the bowl.
Its 100% the carb since I idles great with this 2100. National assures me that it was ran on a test engine and was functional but will take it back and check it again.
Time will tell. I had to leave the jeep at the muffler place. I sat around a little over 2 hours before the got it on the rack then they ran out of the correct size pipe and had to go get more. I was going to stay the whole time and supervise but I think the guy doing it knows exactly what I want. When I left he has the skid cut and the pipes running from the collectors back to where the mufflers will go.
So I am off to pick up Gabby, drop her off at dance, pick up Liam, go back and get Gabby, run home and get the trailer, then make it back to the muffler shop with the kids to load up before they close at 6.
MoC is offline
post #1564 of 2044 Old 03-08-2013, 02:11 PM
ASteve
1972 CJ5
MoC,
Could your carburetor base plate be warpped?
SC
ASteve is offline
post #1565 of 2044 Old 03-08-2013, 02:37 PM Thread Starter
MoC
Originally Posted by ASteve
MoC,
SC
Already checked that. Ran a straight edge across it and looks good. Also did not hear any air leaks when I checked with the stethoscope. Listened with the engine running and with it off when we tried to pressurize the top end.
MoC is offline
post #1566 of 2044 Old 03-08-2013, 06:01 PM Thread Starter
MoC
Done deal. $649 out the door with a warranty from Meineke. Over all I am very happy with the work. I went with a set of Super V's, imitation Flowmasters. The skid plate cuts were not to bad, I just have to pretty them up a bit. I had them hang the pipes out a little long at the rear so I could decided where to chop them. The only little concern is they come out a little closer to the rear tires than I would have liked. It is really tight. He did say that any modifications / changes I wanted he could do under the warranty anytime. Going to ponder on it and see.
Anyone have any constructive criticism?
MoC is offline
post #1567 of 2044 Old 03-08-2013, 06:08 PM Thread Starter
MoC
Here she is running. Keep in mind I have the leaking 2100 on it. The 2100 that all I did to was turn the screews out 2 turns and bolt it on. No tunning. The dirty old leaking 2100 that runs... Not the pretty professionaly rebuilt 2150 that does not yet run.
http://www.youtube.com/watch?v=-xYca...ature=youtu.be
MoC is offline
post #1568 of 2044 Old 03-08-2013, 06:17 PM
lucdog
lucdog's Avatar
1980 CJ5
The cuts look real close to the pipe, might keep a eye out for rubbing. Need shorter bolts on the flanges, maybe stainless.
Sounds real good even with the crap carb.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #1569 of 2044 Old 03-08-2013, 06:23 PM Thread Starter
MoC
Bill
I was planning on shortening those bolts and also cutting some length off the ends of the hangers and painting them up.
The sound is a tad bit louder than I was going for, but not complaining at all.
MoC is offline
post #1570 of 2044 Old 03-08-2013, 06:24 PM
OrangeCJ-5
1978 CJ5
Right side parking brake cable and hose look pretty close. Maybe not
Edit: Upon further review the hose I was referring to looks to be the axle vent hose.
OrangeCJ-5 is offline
post #1571 of 2044 Old 03-08-2013, 06:37 PM Thread Starter
MoC
good eye! I changed out the e brake during the 360 swap and have not tightened it back up yet. That is on the short list.
MoC is offline
post #1572 of 2044 Old 03-08-2013, 06:47 PM
Coiz
1979 CJ7
Sounds great, very similar to my Flowmaster 40's.
I was also going to mention that the passenger's side parking brake cable would get melted the first time that side of the axle drops.
Mike
Coiz is offline
post #1573 of 2044 Old 03-08-2013, 08:07 PM
matthewleeblair
1983 CJ7
Nice moves in the video haha. Sounds great! Also can't wait to get my Jeep to just crank right up like that on a cold start.
matthewleeblair is offline
post #1574 of 2044 Old 03-08-2013, 09:34 PM
GlennLever
GlennLever's Avatar
I would kill the guy for welding a pipe hanger to my frame. It does sound very nice.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #1575 of 2044 Old 03-08-2013, 09:37 PM Thread Starter
MoC
I don't mind it on the frame. There was not another good place to go. I'll cut the top down, grind it a little and paint.
MoC is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
