MoC's Build Thread - Page 103 - JeepForum.com
 3Likes
post #1531 of 2044 Old 02-17-2013, 11:00 AM Thread Starter
MoC
Taking a lunch break.
Working in the harness, still planning in firing today.
MoC is offline
post #1532 of 2044 Old 02-17-2013, 11:01 AM Thread Starter
MoC
Originally Posted by keith460
Looks good and you can never have enough lights under the hood on a CJ!
Thanks Keith. I liked your choice of mounting location the best and went with it.
MoC is offline
post #1533 of 2044 Old 02-17-2013, 07:36 PM Thread Starter
MoC
Anti climatic end to a busy day. Got everything buttoned up with the engine around 7:30pm. Battery hooked up, everything seemed to function electrically including my headlight relays. Tried firing the engine up and I have a timing issue. Had some backfiring out the headers. Played with it for about 5 min and killed the battery. Guess I should have put it on the charger last night.
Going to play with it some more tomorrow afternoon and see if I can get her to fire up.
MoC is offline
post #1534 of 2044 Old 02-17-2013, 07:41 PM
commadore64
commadore64's Avatar
1980 CJ5
MoC... damn nice work even if it ain't running... looks good just sitting still!
1980 CJ-5
My build thread:
Liberalism is the reason why everything else is a problem.
commadore64 is offline
post #1535 of 2044 Old 02-18-2013, 10:27 AM Thread Starter
MoC
My morning job canceled so I re checked TDC and found I was 180 out.
Feel the Thunder!
Edit, you must click on the picture to feel the thunder.
I do have a few issues I am sure. After it ran and got warm is died. Will restart put I have to keep goosing the throttle. Likely a vac leak I am thinking but could also be a fuel flare connection that started sucking air. Either way STOKED!!
MoC is offline
post #1536 of 2044 Old 02-18-2013, 10:44 AM
wm69
Now see, you gott me all worked up and I get "video not found"
BOOOOOOO!
Seriously, looks awesome.
wm69 is online now
post #1537 of 2044 Old 02-18-2013, 11:10 AM
tractor1
1979 CJ5
sounds real GOOD
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4 lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline
post #1538 of 2044 Old 02-18-2013, 01:55 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
MoC
I know how excited you must be. I sure was.
Hook that advance up to manifold and I bet the idle smooths out...
Strong work, man.
Matt
Matt1981CJ7 is online now
post #1539 of 2044 Old 02-18-2013, 02:10 PM
acgcoug
1979 CJ5
I love first "fire up" videos. Looks and sounds bad arse!
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #1540 of 2044 Old 02-18-2013, 02:34 PM Thread Starter
MoC
Originally Posted by Matt1981CJ7 View Post
MoC
Strong work, man.
Matt
It was running on manifold in the video. I had 15 min just now to play with it. Heres what I know. The only way it will stay running at idle is with the idle speed turned all the way up and the advance pushed off the scale. I am thinking I have to have a vac problem somewhere which is allowing it to suck air. Thinking with idle speed all the way up and advance up its compensating for the air leak. Mixture screws are 2.5 turns out and all 8 are firing.
Going to tune on it tomorrow and plug all the vac lines and see what I get.
Matt, question about tuning with manifold vac. With ported you are supposed to plug the advance line when setting the timing. I would imagine with manifold you leave it connected when tuning since it effects your timing at idle, correct? Do you still set your initial time it like you do with ported?
MoC is offline
post #1541 of 2044 Old 02-18-2013, 02:39 PM
lucdog
lucdog's Avatar
1980 CJ5
The timing gets set the same, wether ported or manifold, the line gets plugged.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #1542 of 2044 Old 02-18-2013, 02:48 PM
Matt1981CJ7
1981 CJ7
Yep ^^^^
MoC have you put a vac gauge on a manifold source, yet? What's your idle pressure?
Matt
post #1543 of 2044 Old 02-18-2013, 02:58 PM Thread Starter
MoC
Not yet Matt. I have a dedicated port put just have not hooked it up yet, planning on doing it tomorrow when I start tuning on it.
MoC is offline
post #1544 of 2044 Old 02-18-2013, 02:58 PM
lucdog
lucdog's Avatar
1980 CJ5
Yep ^^^^
Matt
Instead of plugging the vacuum line, hook a vacuum gauge to the manifold vac. carb port. It will serve the same function as a plug in the line .
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #1545 of 2044 Old 02-18-2013, 07:38 PM
commadore64
1980 CJ5
Sounds awsome MoC... makes me wish I was that far along!!!
1980 CJ-5
My build thread:
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
