MoC's Build Thread - Page 102 - JeepForum.com
 3Likes
post #1516 of 2044 Old 02-08-2013, 12:31 PM
fourbtgait
1930 MK Patriot
Nice finds. Sunce the snow is gone here i plan to go pull a family bar tomorrow with some other odds and ends slso.
fourbtgait is offline
post #1517 of 2044 Old 02-08-2013, 12:35 PM
wm69
Originally Posted by bassfsr View Post
The guy I bought the Jeep from is an upholster. He did the seats just before I bought it. When I did the frame off, I just kept the seats as they were. They are out of a Chevy S-10 Blazer I believe.
Almost look like YJ seats that have been redone. Nice looking whatever they came out of. Any way you can verify what they came out of?
Originally Posted by MoC View Post
Nice looking 7!
Have not gotten much done recently. Got my relays mostly wired in but have been sick these last few days.
Made a junkyard run this morning and came back with everything I wanted.
- YJ family bar
- 3 ground bars
- 3 of the retractable lights
- 2 other lights that I just snagged that look like the factory cj ones
My generator fought me and I have to get all MacGyver in it. First the stupid pull cord spooler shattered. Took it apart and was able to spool the cord around a part and pull still. Then with only 2 roll bar bolts to cut it started stuttering and quit running. After a little looking found a fuel line that was cracked and sucking air. Pulled a line from a junk car and patched it back.
What did you get the CJ looking-ish lights out of?
wm69 is offline
post #1518 of 2044 Old 02-08-2013, 12:42 PM Thread Starter
MoC
Same as the bus bars and spool lights, early to mid 90's GMC / Chevy trucks.
MoC is offline
post #1519 of 2044 Old 02-15-2013, 05:50 PM Thread Starter
MoC
Planning on starting this thing on Sunday. My time has been a little limited but here is where I have gotten since I last checked in.
Fender braces and canister rock guard are in.
Got tired of seeing the paint chip on my hood prop rod so I cut some vac line and fixed that problem. Had to drill the lower bracket a little bigger so it would fit.
Radiator and most of the water lines went in.
Got a chunk of electrical work done. I got my relays and head light wiring harness finished up and the lights and buckets back in.
Stuck the relays down on the passenger side inner fender. Still need to get some of the wiring in to conduit, but I am waiting till the engine wiring harness goes in.
The fuse panel for the lights below the interior fuse panel.
I stuck another fuse panel above the center hump under the dash.
Planing on running my cigarette lighter, stereo, and under hood lighting system off of it.
Stuck two 30 amp circuit breakers on the other side of the fire wall. They power the two new fuse panels.
Also got my ground bus bar hooked up.
A few other pictures.
So the list is now pretty short.
- Some misc odds and ends like the rad overflow bottle, wiper bottle, one more heater hose, side mirrors painted and installed.
- I have some touch up / corrective painting to do. Bolt heads and a few spots that I scraped.
- Install the engine harness. Its in good shape just need to lengthen / shorten a few wires, and remove a few things, and stick it all in conduit.
- Wire up my under hood lights and move the cigarette lighter and stereo wiring over to the new panel.
MoC is offline
post #1520 of 2044 Old 02-15-2013, 06:29 PM
CJ7ROB
Looking good.Nice detail
CJ7ROB is offline
post #1521 of 2044 Old 02-15-2013, 06:55 PM
lucdog
lucdog's Avatar
1980 CJ5
Nice!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #1522 of 2044 Old 02-15-2013, 08:34 PM
REDnBLUES
1977 CJ7
Looks good bud
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #1523 of 2044 Old 02-15-2013, 10:50 PM
rixcj
rixcj's Avatar
1979 CJ5
It won't be long now.....you've got to be psyched to fire it up! And...it looks great!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #1524 of 2044 Old 02-16-2013, 06:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Crank the biotch, already.....
Matt
Matt1981CJ7 is offline
post #1525 of 2044 Old 02-16-2013, 10:05 AM
tractor1
1979 CJ5
That looks real good
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4 lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline
post #1526 of 2044 Old 02-16-2013, 02:02 PM
commadore64
commadore64's Avatar
1980 CJ5
Jeep's looking real good. Like what you did with the prop rod.
1980 CJ-5
My build thread:
Liberalism is the reason why everything else is a problem.
commadore64 is offline
post #1527 of 2044 Old 02-16-2013, 08:24 PM Thread Starter
MoC
Thanks guys...
Put some time in today. All I have left now is the engine bay wire harness. Still planing in starting tomorrow.
Let their be light!
MoC is offline
post #1528 of 2044 Old 02-16-2013, 09:22 PM
lucdog
lucdog's Avatar
1980 CJ5
Looksike for a good location. For the reel light, easy to get to when using the hood prop rod. How are the lights turned on that are under the hood?
I know your mounting the MSD on the firewall. Just wondering if you checked clearance with the air cleaner.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #1529 of 2044 Old 02-16-2013, 09:54 PM Thread Starter
MoC
The two lights in the hood have mercury switches and come on when the hood is open.
I was wondering about the MSD myself. The back up plan is moving it down to the fender.
MoC is offline
post #1530 of 2044 Old 02-17-2013, 04:12 AM
keith460
Jeep. There's Only One
keith460's Avatar
Looks good and you can never have enough lights under the hood on a CJ!
1984 CJ-7 Renegade
keith460 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
