Mixed up lifters - Page 2 - JeepForum.com
post #16 of 18 Old 01-13-2010, 09:07 AM
Mike Romain
Originally Posted by Sundowners View Post
Also, It says that this cam is not for fuel injection. Why is that? I 'm planning on doing the "junkyard" TBI conversion. Can I still use this cam?
No, the cams have different settings for FI and carb, same for a non computer engine and computer engine and non EGR and EGR engines. Your distributor advance curve is also tuned to your cam. There is a way to easily change the advance curve on it to match up with a hot cam. JeepHammer has posted the method many times.
Mike
Mike Romain is offline
post #17 of 18 Old 01-13-2010, 09:15 AM Thread Starter
Sundowners
Thanks, I'll do a search to see if I can find it.
B
Sundowners is offline
post #18 of 18 Old 01-13-2010, 08:36 PM
fredrok
The FI cams have essentially less overlap and slightly different lobe centers. (read: valve timing)
If the engine wasn't already torn down, you could get away with a carb cam. They just aren't as efficient as the set up could be.
I'm using Comp Cams 68-232-4 for fuel injection. Outside of a Hesco or lesser known grinder, it's pretty much the only F.I. option from a mass grinder.
MOPAR P5249464 Valve springs
MOPAR P4529218 Valve Keepers
MOPAR P4452032 Spring Retainers
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
Mixed up bearing cups on Dana 30 carrier 1984Laredo Jeep CJ Forum 27 01-16-2010 11:33 AM
Which Lifters elks96 Jeep CJ Forum 2 11-28-2009 08:05 PM
1981 CJ-5 mixed w/ Power Wagon. sweetguardian00 Jeep CJ Forum 2 05-14-2009 03:32 PM
spark cto? lines to them are mixed? quader400 Jeep CJ Forum 2 03-13-2007 09:18 PM
spark cto? lines to them are mixed? quader400 Jeep CJ Forum 5 03-13-2007 06:28 PM
