missing when in action... Please help my 258 - JeepForum.com
post #1 of 14 Old 11-15-2002, 10:07 AM Thread Starter
DIXIE
DIXIE's Avatar
This week I have been trying to get my 258 I-6 running right. I have changed a few parts and done some minor tune up work on it. I still have a bad miss only when the engine is under a load. It runs fine at all rpms when just sitting in the garage, but as soon as you get it out on the road and put the load of moving the engine cust out real bad. Any ideas on where my problem is?
85 CJ-7, 258, 69K, all original except carb and chrome
DIXIE is offline
post #2 of 14 Old 11-15-2002, 10:48 AM
bowhunter
Dixie
Have read some of your other post also. sounds like this problem has been going on for a little while. It may be carb related.
bowhunter is offline
post #3 of 14 Old 11-15-2002, 10:54 AM Thread Starter
DIXIE
DIXIE's Avatar
It has a new carb on it... I am running out of things to check. I am going to try to drain the gas out of it and get new gas to put in it. The gas that is in it has been in there for a while. I didn't have my top when it started getting cold here so it didn't get driven for a while...
DIXIE is offline
post #4 of 14 Old 11-15-2002, 05:28 PM
cj5mudman4x4
Dixie,
I had the same problem with my 73' Cj5, 258 I6, hate to tell u but I had to take my head off so i could boil it out. It was nasty. but have u done anything like that? if u havent had it apart enough to check the pistons u might wanna see if there is any play in ur pistons. Also u might wanna do a compression check. they make little doodads that check ur compression through ur spark plugs. u might wanna give that a go! i boiled my head out and it cleared up for me. also check ur PCV valves for clogging-- wont cause it to miss that bad, but still.
good luck
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #5 of 14 Old 11-15-2002, 05:35 PM Thread Starter
DIXIE
DIXIE's Avatar
Thanks mudman... I might give that a try this weekend. Did yours just start all of the sudden. Mine started in the middle of driving it. Before it ran fine at high (above idle) rpms.
DIXIE is offline
post #6 of 14 Old 11-15-2002, 05:38 PM
cj5mudman4x4
Mine would miss about into 3rd gear. i dunno.. i didnt say before, but mine fixed for about 6 months. It is barely and rarely missing again when it isnt warmed up. I am scared i might have to overhaul the Engine
1973 CJ5
post #7 of 14 Old 11-15-2002, 05:41 PM Thread Starter
DIXIE
DIXIE's Avatar
I am sick of taking it to my mechanic... it doesn't seem like he really does anything for it. That is why I decided to try it myself this time. I have just about run out of things to check before I have to tear into the engine.
DIXIE is offline
post #8 of 14 Old 11-15-2002, 07:13 PM
SamFromCO
SamFromCO's Avatar
Here's one more thing for you to check. Fuel filter.
SamFromCO is offline
post #9 of 14 Old 11-15-2002, 09:50 PM
goody350s
just wondering what your new carb is
is it a carter bbd? i have seen other posts
about enlarging a tube inside the carb itself
they say that has somthing to do with it
missing try doing a search in the forum
about this subject
i dont know but maybe that would help
anyway just my .02
75 jeep cj5 project
goody350s is offline
post #10 of 14 Old 11-15-2002, 11:09 PM Thread Starter
DIXIE
DIXIE's Avatar
about this subject
anyway just my .02
I have already drilled out the idle tubes on my carb. Thanks for the info though.
DIXIE is offline
post #11 of 14 Old 11-20-2002, 06:44 PM
jeepin cj-5
I have a 73 cj5 also and it souds lik i may have te same problem. How did u boil it out.. and what does boiling it out do?
jeepin cj-5 is offline
post #12 of 14 Old 11-20-2002, 08:31 PM
cj5mudman4x4
to tell u the truth i don't know why i said boiled out. i was not all there when i posted that.. what i meant was, i had a valve job done and i had my head TRUED UP, not boiled. it was warped which is common. so look for that. and if u get it all apart check ur pistons.. i found out that i am gonna have to bore out my engine so i am sad, but anyways.. good luck
1973 CJ5
post #13 of 14 Old 11-21-2002, 03:53 PM
jeepin cj-5
ok things make sense now... Yeah i have been thinking that i might need a valve job... I biggest problem is that it burns oil like its gas. Not sure exactly what that means.. must be the seals
post #14 of 14 Old 11-22-2002, 12:42 AM
Jeep Daddy
Jeep Daddy's Avatar
Do a compression check and post that information. If the compression is good, get a new carb. I know you said you already put a new carb on it, but that is impossible since you can't get a new carb and some rebuilders do not have great rebuilds. There are a few rebuilders that CAN do BBD's. Some can't. Or, get an aftermarket Weber or a MC2100. You might want to take it to a mechanic to scope it. Scoping it will tell you if your spark is good to ALL cylinders. It won't tell you if you have low compression or need a valve job.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Noob questions on transmission/transfer case action jbcarney Jeep CJ Forum 2 12-13-2009 06:22 AM
missing gas Viencent Jeep CJ Forum 7 04-22-2009 10:09 PM
Lets See Spring Over Action lagestee06 Jeep CJ Forum 17 04-15-2007 10:58 AM
Missing out adam85cj7 Jeep CJ Forum 4 02-25-2007 12:11 AM
Jeep back in action.... Raiderfanatic Jeep CJ Forum 2 07-09-2005 04:25 PM
