Missing Warn lock out Dana 30 Wide track. - JeepForum.com
post #1 of 8 Old 08-21-2013, 06:54 PM Thread Starter
Jiffy
1983 CJ7
I'm just looking for opinions.
Stolen or Not Stolen?
I used my Warn lock-out on 1983 CJ 7 wide track Dana 30 about a month ago. Everything worked just fine and I didn't notice anything loose.
Now all 5 bolts and it's cover is completely gone?????
Could it have loosened up that much fallen off and I never heard it or felt it?
Or was it stolen?
It's driving me crazy and I'm curious if this has happened to anyone else.
Thanks
Jiffy is offline
post #2 of 8 Old 08-21-2013, 06:56 PM
jeepwhore
They fall off....it's definitely not unheard of. Look in the bolt holes, I'd bet you find at least one with a broken off bolt (although that's not always the case. The first time I lost one it was sheared bolts, the second time it was loose bolts.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 8 Old 08-21-2013, 07:04 PM
LumpyGrits
That's the why, most folk use studs and nuts
Get yourownself a set of Mile-Marker hubs, and never look back.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 8 Old 08-21-2013, 07:41 PM Thread Starter
Jiffy
1983 CJ7
Thanks guys.
I picked up a jeep standard cover on Craigslist and they are interchangeable with the Warn standard and the only difference is the mechanism that you hand turn. The Warn turns about 9/10ths to engage and the old jeep one goes most of the way around.
I will have to buy a new set, but this will get me by until I feel like spending $200.
Jiffy is offline
post #5 of 8 Old 08-21-2013, 07:54 PM
LumpyGrits
Make sure it's not a 6 hole mounting.
MM don't cost $200.00.
http://www.jcwhitney.com/supreme-loc...1&skuId=221866
You can find'em cheaper too.
LG
post #6 of 8 Old 08-21-2013, 08:33 PM
jeep_boy02
1980 CJ7
Contact warn, im sure they'd sell replacements so you dont have to buy a whole new kit. Throw some loctite on the next set maybe?
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #7 of 8 Old 08-22-2013, 01:34 AM
TRUVOL
I've had my cj for 10 years now and mine have never fell off. Then again I regularly grease my wheel bearings. Get some locktite.
TRUVOL is offline
post #8 of 8 Old 08-22-2013, 08:01 AM
wm69
I've had them loosen, but not fall off. It does happen though. Get studs with loctite, and use nuts to hold the hub on the studs.
wm69 is offline
