missfiring when cold? - JeepForum.com
post #1 of 11 Old 09-10-2012, 09:04 PM Thread Starter
Alex77cj7
1977 CJ7
So recently my 77 cj7 304 has started misfiring when first started and running really rough for the first 15-20 minutes of driving. When i first start it, it misfires really really bad and if i rev up the engine for a minute or two it stops.
Has anyone had this problem before? What causes it? It wasn't doing it before I readjusted my timing.. Could I have cracked the prestolite distributor?
Any and every bit of help is greatly appreciated.
Thanks,
Alex.
Alex77cj7 is offline
post #2 of 11 Old 09-10-2012, 09:07 PM Thread Starter
Alex77cj7
1977 CJ7
Also seems to be taking longer to start in certain circumstances. It also still backfires under load. I was going to do the team rush upgrade soon. Do yall think that that would help?
post #3 of 11 Old 09-11-2012, 01:47 AM
row684
Sounds like your choke to me, check to make sure the wire is still hooked up to it and getting power
row684 is offline
post #4 of 11 Old 09-11-2012, 04:33 AM
RWise
1981 CJ5
yep, check the choke!
RWise is offline
post #5 of 11 Old 09-11-2012, 07:11 AM Thread Starter
Alex77cj7
1977 CJ7
I've checked my choke plenty of times. I'm running a brand new holley truck avenger 600. The choke closes all of the way and stays choked long enough for my engine to warm up.
post #6 of 11 Old 09-11-2012, 10:08 AM
Centerfire
I don't think the choke is suppose to close ALL the way.
Some air needs to go into the carb for the proper mix.
Centerfire is offline
post #7 of 11 Old 09-11-2012, 11:09 AM Thread Starter
Alex77cj7
1977 CJ7
Oh I thought it was supposed to fully seal! Okay so should I try backing it off till its open a little?
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
post #8 of 11 Old 09-11-2012, 11:11 AM
Centerfire
Just a little.
post #9 of 11 Old 09-12-2012, 04:47 AM
RWise
1981 CJ5
This time of year in the swamps, about 1/3 open, I set mine in cold weather,,,,,
RWise is offline
post #10 of 11 Old 09-12-2012, 05:33 AM
Hawk4097
When cold the choke being closed is the right position but should quickly start to open up. When you put the carb on did you adjust the adjustment screws? make sure how ever many times you turn one side you turn the other the same. That can cause backfiring. You may want to bust out the timing light as well and ensure that your timing is correct. Also to rule it out do a spark check on all cylinders.
Hawk4097 is offline
post #11 of 11 Old 09-12-2012, 10:52 AM Thread Starter
Alex77cj7
1977 CJ7
That's how my choke works now! When I put the carb on it ran perfect! Just had to adjust the idle speed. Then after a week or two I had to tune it using the mix screws. I also set the timing the same day. All my plugs and wires are brand new accels. And it stops missing after I rev it up! But when I rev it up to make it stop it blows white smoke!
running cold... wh74415 Jeep CJ Forum 30 08-22-2011 05:28 PM
Cold weather in Texas, cold starts Ken4444 Jeep CJ Forum 6 02-02-2011 09:52 AM
Cold Air CJhollic Jeep CJ Forum 14 10-26-2008 01:03 PM
Cold Starts? Hybrid Jeep Jeep CJ Forum 14 12-17-2007 06:24 PM
cold blooded 304 zeke01 Jeep CJ Forum 1 05-22-2007 12:32 PM
