Miss at idle - JeepForum.com
post #1 of 15 Old 06-05-2014, 12:33 PM Thread Starter
Jeepit85
Miss at idle
I have installed a new 258. Motor misses at idle. Prior 258 did the same. I have had the Howell TB on both motors and new DUI installed on the new motor only. Old motor missed the same as the new. I have swapped out computers a several times and even had a modified one from Howell shipped to me. Same idle miss occurs.
What might be causing this?
85 CJ7, Howell TBI, Twin Stick, 4:10's, 35" Pitbull Rockers, Clifford 6=8, Detroits, Matkins Level II, BDS 4", Summers Brothers. Skynyrd rocks.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #2 of 15 Old 06-05-2014, 12:37 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Does it stall at idle ? If not, I would call it good.
A 29 year old Jeep may have some quirks.
CJ7-Tim is offline
post #3 of 15 Old 06-05-2014, 03:39 PM
Dngrs1
1979 CJ7
Did you reuse the plug wires?
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #4 of 15 Old 06-05-2014, 04:14 PM
LumpyGrits
Spray the spark plug wires with soapy water. Does it get worst??
Ck ALL manifold bolts to be sure they are tight(vacuum leak).
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 15 Old 06-05-2014, 04:14 PM Thread Starter
Jeepit85
Does not stall at idle.
All new wires and plugs went on new motor.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #6 of 15 Old 06-05-2014, 04:17 PM
LumpyGrits
Look for vacuum leaks then--
Make sure you don't have cross-firing inside the dizzy cap.
STILL- soapy water test the SP wires.
LG
post #7 of 15 Old 06-05-2014, 05:31 PM
CJ7-Tim
CJ7-Tim's Avatar
My CJ-7 and both my XJ's have a lumpy idle. I don't think the Jeep in-line 6 cylinder was ever known for it's smooth idle.
CJ7-Tim is offline
post #8 of 15 Old 06-05-2014, 05:45 PM
LumpyGrits
You would be wrong then.
Mine W/119+K miles, idles as smooth as any. Passes SMOG with ease.
BTW-the 258 was based on a tractor engine.
Any 'miss' at idle should be looked into.
LG
post #9 of 15 Old 06-05-2014, 06:15 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I have to disagree with this. Here's my 258, with 98K original miles, after I installed and tuned a Weber 38.
Turn the sound down and see if you can detect a single vibration at idle.
Matt
Matt1981CJ7 is offline
post #10 of 15 Old 06-06-2014, 12:21 AM
BagusJeep
1981 CJ7
The Cherokee idles like a sewing machine, the J20 does not even with the Teamrush upgrade and new wires, Jeepputhi and Bagus are smooth as butter and stock.
So some do and some don't.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #11 of 15 Old 06-06-2014, 07:05 AM
Mike Romain
How did you hook up your gas tank vent? When the air filter on mine is getting dirty, the idle gets lumpy. When I crack open the gas cap and the idle pops up and smooths right out, I know it is time for a new vent air filter.
Mike
Mike Romain is offline
post #12 of 15 Old 06-06-2014, 12:51 PM
steve1973
1973 CJ5
My 73 with 46k miles and a imposter weber 34 is silky smooth at idle. You can balance a dime on edge on top of the hood at idle.
steve1973 is offline
post #13 of 15 Old 06-06-2014, 03:36 PM Thread Starter
Jeepit85
Are they not vented to the canister? At least that is what I thought.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #14 of 15 Old 06-06-2014, 08:47 PM
Mike Romain
Yes and the canister has to have a ported switched purge line to manifold vacuum or it saturates the charcoal with fumes which puts a vacuum on the gas tank. The canister has an air filter on the bottom for when it purges that is prone to getting filled with mud or dust which will do the same.
Mike
post #15 of 15 Old 06-07-2014, 08:22 AM
RWise
1981 CJ5
Mine would idle for a moment good and then start missing. Turn it off and look down its throat to see fuel standing in a puddle. For this I removed one of the 2 holes below the carb (made it into one large hole), re-tuned it and it now idles perfect! I used the OEM manifold from the 258 (on my 89 4.0) a hammer and chisel to open it up, left the roughness also. (gaskets/spacers cut away as well, open and say ahhhhhh)
I would suggest removing the manifold to do this, cut out the X first then the rest. Edit; my manifold is aluminum, cast iron would be more difficult, dont use a chisel here!
The 2150 carb I ended up with has no place for the return line, so I picked up a canister for the 89 xj engine which has no place for a vacuum line or return line. Its just a very large filter to let clean air into the tank. I have no tests to pass,,,,
RWise is offline
