Milky rear end fluid..... - JeepForum.com
post #1 of 27 Old 09-03-2013, 10:23 AM Thread Starter
JeePete
1983 CJ7
Anyone have any bright ideas? I used the CJ to launch my boat and it was a VERY low tide, so the rear end was submerged.
Looks like the rear brakes "T" block is missing the mounting bolt and let water in. I'm draining it now, but any ideas on cleaning (or potential damage) before I refill with new gear oil?
Thx,
PK
JeePete is offline
post #2 of 27 Old 09-03-2013, 10:41 AM
twoleos617
I would say you'll be ok since you cought it early. Obviously you'll need to find a replacement bolt first thing. Get it cleaned out with cleaner and some rags. Get a new gasket and skim coat it on both sides with some RTV following its directions. Will need to cure overnight I believe. Then refill.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #3 of 27 Old 09-03-2013, 10:52 AM
scoutboater
1974 CJ5
Brake cleaner works pretty well at getting all the crud out of it too. Just watch out, when you shoot it in, it will shoot back out somewhere...
Also, if you have a limited slip rear-end or anything like that, make sure you use the correct additives for it.
scoutboater is offline
post #4 of 27 Old 09-03-2013, 11:02 AM Thread Starter
JeePete
1983 CJ7
Thanks....
Mike & Scout- Any thoughts on needing to get the brake cleaner into the outer bearing?
Hopefully I caught this in time and thankful to the PO for NOT doing a good job with the gasket sealer......white spot on the floor of the garage is what started me thinking....
JeePete is offline
post #5 of 27 Old 09-03-2013, 11:12 AM
scoutboater
1974 CJ5
I didn't worry about the axle bearings when I changed the fluid in mine, and I've had no issues. Once you re-fill with fresh clean oil, whatever is still hanging around way out at the wheels should be well enough diluted with the fresh oil that you don't have to worry about it.
On the other hand, if you are really worried about it, clean the chunk out, fill her up with cheap gear oil, drive her a little bit, then repeat with the good stuff. That will ensure that the outer bearings are running in nice clean new oil.
post #6 of 27 Old 09-03-2013, 11:22 AM
twoleos617
X2^
Mike D.
post #7 of 27 Old 09-03-2013, 11:35 AM Thread Starter
JeePete
1983 CJ7
Did I mention it was SALT WATER I was backing down into?
JeePete is offline
post #8 of 27 Old 09-03-2013, 03:19 PM
Spieg8
1984 CJ8
Just check for any rust while you are cleaning the muck out. Water/oil mix is not the best gear lubricant in the word, but usually doesn't do damage unless metal is exposed for a length of time. If the PO had water in it before you bought it, you may have a bigger problem.
Spieg8 is offline
post #9 of 27 Old 09-03-2013, 04:22 PM
scoutboater
1974 CJ5
While that would make me lean towards the double flush a little more, I still probably wouldn't worry about it since you caught it so fast if everything looks good inside.
post #10 of 27 Old 09-03-2013, 04:42 PM
wellmax
I would drive the jeep long enough to get the differential hot, then drain the oil, do this three times.
you should be good if no damage has been done up to this time.
using the type cleaning agents might cut all the oil off a bearing and it not be properly lubed by your refill.
I had a motor leak coolant and fill the oil sump, as long as the bearings are under water they do not rust with coolant.
drained the coolant/oil, fixed engine, new oil ran it a few miles then changed oil again, traded off the truck after 5K miles and it was still running good.
wellmax is offline
post #11 of 27 Old 09-03-2013, 06:51 PM
WindKnot
1977 CJ7
Your bearings should be in grease, not the differential oil. That's what the inner oil seal is for. Some people have discarded the inner oil seal and let the diff oil lube the bearings. It's NOT how Jeep set it up though.
If both the inner and outer of your oil seals are good, the bearings should be okay. Inspect them if you want, but it's going to be some work.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #12 of 27 Old 09-04-2013, 09:10 AM
scoutboater
1974 CJ5
Good point. I wasn't even thinking about that.
post #13 of 27 Old 09-04-2013, 11:00 AM
CSP
Does the AMC20 have an inner seal? Not all rear axles do and many are supposed to bathe the outer bearings in gear lube. The '72-75 CJ Dana 44s are set up this way.
CSP is offline
post #14 of 27 Old 09-04-2013, 11:27 AM
Spieg8
1984 CJ8
According to the FSM, there are 3 seals in an AMC20. 1 at the pinion and one at each axle bearing (by the brakes). I remember my old model 20 never leaked, but would fill with water every time I crossed a creek.
Spieg8 is offline
post #15 of 27 Old 09-04-2013, 01:33 PM
WindKnot
1977 CJ7
^^^^That's COMPLETELY WRONG. Go re-read your FACTORY Service Manual. Each axle has an inner seal and an outer seal.
Inner Axle Seal...
Outer Axle Seal...
WindKnot is offline
