Mile Marker locking hub fitting issues - Page 2 - JeepForum.com
post #16 of 20 Old 04-07-2013, 06:21 PM Thread Starter
Renegade82
1982 CJ7
Yes, everything, seal and bearing wise is new. I don't believe the spindle brg. is seated to anything. I believe I read that as long as it's an even seat so that it's in far enough to allow the seal's top to be just below flush, being that it's a sleeve type brg. that has no side thrust and isn't a two pc. like a brg. and a race that must mate squarely. Plus it leaves room at the other end to grasp with a puller. Is that wrong, does it have to seat deeper? That's where the seal was located when I removed the old one. Theres not really a "seat" in there.
Anyhow, so I get to dissecting things further. I find a tiny bit of thicker paint and ground that down. No burrs, dings, dents on the spindle or knuckle hole. And I tried rotating the spindle to each of the 5 positions to see if one fit better. But what I did notice was while either rotating the hub or the spindle, the axle / spindle non gap side (where I couldn't get the screwdriver tip) was always in the same spot, which was towards the top, or right, as the axle lays [cover up, yoke down]. And as I stood there staring, waiting for it to fix itself (didn't happen, didn't even move ) I noticed it was off in the same direction as the knuckle fits on the axle's "C". As if tightening the ball joint nuts would pull the knuckle/spindle in the right direction to line up the axle and spindle. I have a picture that illustrates it well but I'll have to post it tomorrow.
So I thought... could it be that simple, the ball joints just weren't tightened enough! So Saturday I went to the local shop that did my axles rebuild which included new ball joints, to pic his brain and to see what torque he did the ball joints too. He said he doesn't remember but it's probably the typical 70-75 ft/lbs. I thought great, it's supposed to be 85 on the bottom, 50 on the split ring and 100 on the top nut. I thought that's got to be it.
I was able to etch my tub that afternoon so I didn't get back to the axle till sat. night and I wasn't alone. Mr Murphy was in full force that night. Turns out the bottom nut was plenty tight. Curious as to what he did torque it too I started at 70 ft/lbs and moved up in 5 lb increments to see at what point I could move the nut tighter. At 105 lbs I moved it. Now I don't know that that's an accurate way to check it or not, plus it was painted with POR so I don't know if that could add any strength to it or not. So I backed the nut off some and retightened it to 85 ft/lbs. Then I went to loosen the top nut and it was a size I didn't have. Fifteen minutes till close I ran to Lowe's for a 1 5/16" socket and they didn't have one. The closest metric they had, using a tape measure in the store, was a 36mm. Could it fit? So I grabbed it, got home, and not such luck. Dead in the water.
Then I decided to start doing the tie rod flip, so I taper one hole and it doesn't go like the instructions say it will. Nothing like it! Dead in the water again at that point.
So I figured well, to feel like I got something done I'll put the other end together. Things were going good till I went to put the cap back on the hub with the little (#8x32) allen head cap screws. One of them had boggered threads at the end, which I noticed it being tight on removal. Rooted around and luckily I had a die to fit that size (what were the odds). So after fixing up the threads, then installing the cap with the gasket, a dusting of silicone, and a dab of locktite on each of those screws. I was done. Turn from free to lock.... works great. Now turn back to free.............................!@#$%^&*
It's 2:53am. I give up. Well played Mr. Murphy!!
Could I have a bad ball joint? What's the odds. So the saga continues, suggestions welcomed.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #17 of 20 Old 04-09-2013, 10:20 AM Thread Starter
Renegade82
1982 CJ7
Well I got the cap turning issue figured out. They really need to include way better directions than just a generic drawing. There are 5 different positions the cap could go for "free" and 5 for "lock" but only one position fits with the 3 tabs inside in the right position. So mark the hub body and cap with tape before separating and note how the inner sleeve is sitting. Anyways, I got that issue solved.
I didn't do anymore to the whole alignment issue on the other end but heres some pics to show how much it's off by, that's creating this whole mess. At this point I'm thinking the ball joints aren't seated fully or I got a bad joint.
If the outer knuckle moved close to the axle "C", it would move the spindle closer to center. The bottom pic illustrates my theory. What do you guys think? I'm out of guesses and it's slowing my progress way down.
post #18 of 20 Old 05-10-2013, 11:45 AM Thread Starter
Renegade82
1982 CJ7
Well I believe the problem has been solved. It's not completely together but the spindle fits well and the axle isn't tight to the side. I had the ball joints pressed out and 2 new Raybestos ones pressed in. I'm not sure which one it may have been or if one wasn't fully seated but I believe the issue is solved. I'll know tonight when I finish assembling it but so far it looks like the issue was the ball joint wasn't allowing the knuckle to fully mate together and just that little bit threw off the axle shaft alignment.
post #19 of 20 Old 05-10-2013, 09:45 PM
Colt44
1983 CJ7
Looks like you have the important mechanical stuff pretty much sorted out, but if you have a problem getting those Laredo center caps to fit, you might want to check out this thread:
http://www.jeepforum.com/forum/f8/mo...-rims-1503121/
I went through this a few weeks ago with a set of Warn hubs, and that was my solution.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #20 of 20 Old 05-10-2013, 11:56 PM Thread Starter
Renegade82
1982 CJ7
Yep, I got it all together with no issues. Finally! No center caps going on mine.
