Metal door repair - JeepForum.com
post #1 of 3 Old 11-29-2005, 09:08 AM Thread Starter
mforbes
mforbes's Avatar
Metal door repair
I could use some ideas...
My 1979 factory metal doors with rollup windows have a stress crack/fracture in the metal. The crack on the inside is nearly 2" long and only about 1/2" on the outside. This crack is on the window side of the wing-pillar going downward. The metal is very thin and this is likely the problem. I have thought of just screwing a small aluminum angle to the door, extending well past the crack in both directions. Any ideas would be much appreciated.
Also is there a trick to removing the door-pannel that I should know about.
Thanks for the help.
1995 Wrangler SE, 4.0L HO, 5sp.
31" BFG Mud TA, Posi-Lok
5/8" greasable boomerang shackles
Shade-Tree-Fab F/R bumpers
Switched from CJ's after 20+ years!
Just another Toy...
mforbes is offline
post #2 of 3 Old 11-29-2005, 12:42 PM
GPER
1979 CJ7
The crack has hit us all I have welded mine and redone them and even had a spare set of doors. Over the 26 years of having my Jeep the doors are getting bad and they are a pain to work on. There was a write up somewhere where they cut a piece off of another car door that fit the Jeep door, I don't have it anymore you might search the net on that one. I thought about YJ doors and just putting the door pin on the tub, but I found a set of fiberglass doors at a swap meet. I don't have them ready to go on yet, but JC Whitney has all of the door and window seals in a kit if you are looking for that stuff.
GPER is offline
post #3 of 3 Old 11-29-2005, 03:04 PM
frankinjeep
to stop the crack drill a hole thru the end of the crack
frankinjeep is offline
Full Metal Door(s) Overhaul AbercrombieCJ7 Jeep CJ Forum 69 04-16-2013 10:26 AM
Hard Door Crack Repair nedmoore Jeep CJ Forum 14 02-12-2010 09:51 PM
Half door beyond repair? Aduffy32 Jeep CJ Forum 2 01-25-2010 01:06 PM
Body Repair ???? Metal Prep Pog Jeep CJ Forum 10 12-17-2008 09:05 AM
Hard door repair? TheJunkMan2005 Jeep CJ Forum 1 06-08-2005 07:33 AM
