mehaaaa all that work - dauntless crapin oil - JeepForum.com
post #1 of 20 Old 09-20-2012, 10:07 PM Thread Starter
molsenice
1964 CJ5
Well as some of you know, I just spent more than i planned and way more time than I wanted installing a 1971 v6 Dauntless into my 64 cj5.
I had run the engine briefly prior to the project and had been told it was "GOOD TO GO" as far as the engine was concerned before I bought the jeep it was in.
well - it was smoking after it was good and warmed up - I figured it was stupidity on my part as I had poured oil over the rockers since I had the valve covers off - oil defiantly got into some of the cylinders - but not this much.
To give you an idea, the custodian @ school asked me if I was fogging for sketers this morning
I was thinking valve seals since the breather is clear and the PVC is new - well lets say I was hoping.
well, get this......Valve seals are not available - according to NAPA or any searching I have done on line.
Then I thought about something I read... the odd fire is just a v8 with 2 cylinders lopped off...so Buick V8 valve seals from 1971 should work....????
I also read that Marvels mystery oil works wonders - thou I always thought of the stuff as snake oil. But since I read claims of oil rings being freed up and lifters being freed up - smoking engines not smoking anymore - who cares 5 bucks. You never know - with this stuff I might even walk on water.
Obviously the thread title gives it away - she's not just smokin n chokin - after the marvels automatic transmission fluid (that's what it looks like)- I have oil leaking out the exhaust pipe - just Fking greaaat~!
most likely going after a complete engine overhaul - I suspect the rings are burnt, nothing blows oil like this and suddenly stops - so I will smoke a few more days and then pull the trigger - back out she will come
My butt hurts
molsenice is offline
post #2 of 20 Old 02-03-2013, 07:25 PM Thread Starter
molsenice
1964 CJ5
pulled the engine a few days after this post then it became a hose hanger, crap holder and generally buried in the garage. I got every excuse -a Senior Vasity soccer season, swim season, hunting season - bla bla bla. ( I did score a nice 6ptr)
Finally tore into her this past weekend and found # 3 had snapped the intake push rod, #6 had an exhaust push rod bent almost snapped.
the full rebuild is about to begin - but the funding I had lined up just evaporated, will press on
post #3 of 20 Old 02-03-2013, 09:41 PM
John N
1981 CJ8
I might know where there's one in good shape if you want another. A friend had it a few months ago. It had an Offy intake on it and some other good stuff. Might be a good deal, he has no use for it.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 20 Old 02-03-2013, 09:51 PM Thread Starter
molsenice
1964 CJ5
send me the info please - can't hurt - i currently have a pile a pieces, it's only money
post #5 of 20 Old 02-04-2013, 03:17 PM
John N
1981 CJ8
Oh well. He sold it in December. You might consider a junkyard 231. It'd probably be cheaper than a re-build and a lot more power.
John N
John N is offline
post #6 of 20 Old 02-04-2013, 03:30 PM
timgr
1975 CJ6
How would a 231 have more power than a 225? The slight increase in displacement won't make much difference.
IME push rods bend due to over-revving, or when the valves freeze in the head. Have you had the heads off yet? I'd hold out some hope that I could fix it up, but I'd want to inspect everything closely.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #7 of 20 Old 02-04-2013, 09:38 PM
John N
1981 CJ8
It's not the displacement, but heads that flow way better. They were called hi-port heads when the 231s first came out.
John N
John N is offline
post #8 of 20 Old 10-26-2013, 07:42 PM Thread Starter
molsenice
1964 CJ5
Welp - waitin on the postman - parts are ordered and the reconstruction thou long delayed will soon begin
push rods, rings, gaskets, bearings - check!
gotta clean the build area
post #9 of 20 Old 10-27-2013, 02:39 AM
John N
1981 CJ8
Get to work.....I don't have 225 parts laying around any more.
John N
John N is offline
post #10 of 20 Old 10-27-2013, 03:21 PM
John Strenk
John Strenk's Avatar
1976 CJ5
There was something I read some place about knurling the valve guides. I think it had to do with oil leaks through the valve seals.
John Strenk is offline
post #11 of 20 Old 10-28-2013, 05:28 AM
gmakra
Any competent machine shop should be able to rework the heads. This may include machining the valve guide boss to accept a different valve stem seal.
John knurling valve guides really dosent help the oil control as much as displacing metal to get the valve guide back to OEM spec.
gmakra is offline
post #12 of 20 Old 11-14-2013, 02:17 AM Thread Starter
molsenice
1964 CJ5
unbelievably - I wrestled with a wood spliter and lost - still have all my didgets - but the right thumb is going to be in a splint for the next 6 weeks - surgeon says I should regain full use and there is a good chance a nail will grow back
going to try to move ahead - but with one hand its going to be difficult
post #13 of 20 Old 01-02-2014, 09:32 PM Thread Starter
molsenice
1964 CJ5
Thumb outta splint - get to keep thmb
Christmas vacation has been productive
http://youtu.be/7_t-d_2zeM4
post #14 of 20 Old 01-02-2014, 10:11 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Great little video! The engine look fabulous! By the way, was the thumb in the "thumbs up" the one you got to keep?
God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #15 of 20 Old 01-03-2014, 01:53 PM Thread Starter
molsenice
1964 CJ5
God bless.
Jon In Tucson
YES IT WAS!
Help! from someone that has dauntless 225 flybyer Jeep CJ Forum 1 09-28-2010 03:54 PM
Dauntless 225 run dry :( PostaljeepSS Jeep CJ Forum 27 07-15-2008 06:40 PM
Dauntless Experts!! lmdguy Jeep CJ Forum 20 10-10-2006 04:26 PM
Looking for a Dauntless V6 dikapos Jeep CJ Forum 10 12-05-2005 05:59 PM
1970 CJ-5 Dauntless V-6 frontlander Jeep CJ Forum 2 10-23-2002 08:57 AM
