Meh, just wheel it..CJ build - Page 6 - JeepForum.com
post #76 of 143 Old 10-17-2013, 05:53 PM Thread Starter
OldCJ
1978 CJ5
I worked on upgrading the heater blower today. It sucks because the heater fan is inside the cab, so the pm102 fan is spinning the wrong direction, but still a huge upgrade in air volume.I unbolted the original panel, unbolted the fan, and enlarged the mounting hole to let the nose of the motor fit through. I used the squirrel cage from a different fan, I'll get some dimensions and part numbers when I take it back apart to seal it.
OldCJ is offline
post #77 of 143 Old 10-17-2013, 06:21 PM
Mace350
Awesome Jeep, just read through the thread.
Mace350 is offline
post #78 of 143 Old 10-17-2013, 07:41 PM Thread Starter
OldCJ
1978 CJ5
Thank you, sir.
OldCJ is offline
post #79 of 143 Old 10-28-2013, 07:12 PM Thread Starter
OldCJ
1978 CJ5
Heater fan upgrade. I drilled a hole in the box and added a resistor assembly to control fan speed. For those playing the home game, the correct part # for the under-dash fan is PM 113 from Autozone. Counter-clockwise rotation, from an early 90's S-10. I ground the flat spot on the shaft to bring the fan as close to the mounting plate as possible. I still had to shim the mounting plate away from the heater box about 1/8 of an inch. Unbelievable the amount of air this thing pushes! I also added a fan speed resistor for high and low speeds. If I change to a four position switch I could use both coils and have 3 speeds.
OldCJ is offline
post #80 of 143 Old 10-28-2013, 07:16 PM Thread Starter
OldCJ
1978 CJ5
Cut and spliced dash to move the glove box to clear roll bar. Still using an old motorcycle battery box mounted on the dash for dry storage. Cell phone, smokes and mp3 player go in there. No radio, but the cord draped over the box goes to the amp mounted under the driver's side seat.
OldCJ is offline
post #81 of 143 Old 10-29-2013, 12:40 PM
ScroungerLee
Good looking Jeep, I love when they are more purposeful than pretty. Looking forward to more.
ScroungerLee is offline
post #82 of 143 Old 10-29-2013, 04:26 PM Thread Starter
OldCJ
1978 CJ5
Like Red Green said, if women don't find you handsome, they should at least find you handy. The same with Jeeps, I guess.
OldCJ is offline
post #83 of 143 Old 10-29-2013, 05:09 PM Thread Starter
OldCJ
1978 CJ5
I also cut down an old ammo box to replace the paper glove box, and cut down some old universal choke cables to replace the broken heater cables.
OldCJ is offline
post #84 of 143 Old 10-31-2013, 08:11 AM Thread Starter
OldCJ
1978 CJ5
I guess I didn't post it before, but I used two rear seats with sliders from a Chevy Venture van in the back. I'll get some pics of the mounts I made later.
OldCJ is offline
post #85 of 143 Old 12-14-2013, 12:51 PM Thread Starter
OldCJ
1978 CJ5
The grille lights are stop tail and turn lights from a truck supplier in Burton, MI. I had to enlarge the openings in the grille to make them fit.
OldCJ is offline
post #86 of 143 Old 12-14-2013, 12:53 PM Thread Starter
OldCJ
1978 CJ5
I got the LEDs in finally. I'm still working on getting the old steel top restored and installed.
OldCJ is offline
post #87 of 143 Old 12-14-2013, 12:54 PM Thread Starter
OldCJ
1978 CJ5
OldCJ is offline
post #88 of 143 Old 12-20-2013, 11:50 AM Thread Starter
OldCJ
1978 CJ5
Kinda confused now. The steel top I am restoring for the 74 is definitely a Kelly Steel top, with the indents in the side walls and the forward-angled area above the windshield, like the one in post 13 here http://www.jeepz.com/forum/cj-yj-tj-...steel-cab.html . The other top I have on my 78 is shaped the same, but with no indents (maybe just a production change?). Anyone know?
OldCJ is offline
post #89 of 143 Old 12-23-2013, 05:35 PM Thread Starter
OldCJ
1978 CJ5
Blah blah. Hibbity hooplah! Just thought I'd say that.
OldCJ is offline
post #90 of 143 Old 12-23-2013, 09:46 PM Thread Starter
OldCJ
1978 CJ5
I have no lift gate to go with this top, so I used the measurements from the other one I have to fab one up. One of the lift supports I have is bad, so I'm thinking of using something like these. http://www.autozone.com/autozone/acc...er=853922_0_0_
OldCJ is offline
CJ7 Spacing from wheel to wheel Dlongj Jeep CJ Forum 2 05-05-2009 01:24 PM
No Wheel/No Steal System for Grant Steering wheel Ridettu02 Jeep CJ Forum 12 11-11-2008 01:44 AM
Wheel Slop. Ball Joints or Wheel Bearings? DT5150 Jeep CJ Forum 8 07-07-2008 01:37 PM
**DEBATE** Build up cj2a or buy and build up cj5 Kevin Swayze Jeep CJ Forum 4 02-06-2002 03:07 PM
