Mechanical temperature gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Mechanical temperature gauge
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 03-18-2014, 07:02 AM   #1
Clint68
Just bought 82 cj7 with 6cyl. Temp. And gas gauge do not work. I plan to drive thru summer and fix original gauges next winter. I don't like driving without knowing eng. temp. What would be a good gauge to buy? Where would be the best place to mount sending unit. Thanks
Clint68 is offline   Reply With Quote
Unread 03-18-2014, 07:51 AM   #2
rixcj
rixcj's Avatar
1979 CJ5
Autometer makes the "Traditional Series". They resemble the stock jeep gauges. It could replace your factory gauge.
Lots of websites sell them.
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote
Unread 03-18-2014, 09:48 AM   #3
John Strenk
John Strenk's Avatar
1976 CJ5
If it's just temporary, get an under dash bezel and install it there.
Mechanical water temp sensors are huge, best to get a 4.0 thermostat housing and install it there. There are also two ports on the block under the exhaust manifold that could be used.
John Strenk is offline   Reply With Quote
Unread 03-18-2014, 11:20 AM   #4
crouse11c
Have you looked under the hood to see if the temp gauge is hooked up and checked to make sure the gauages are hooked up correct with a good ground
crouse11c is offline   Reply With Quote
Unread 03-19-2014, 03:46 PM   #5
Bubba Ray
I did what rixcj says and have been very happy with that set up for years. Plus it is fun to watch temp go up after you switch the jeep off.
Bubba Ray is offline   Reply With Quote
