Mechanical temp sender - JeepForum.com
post #1 of 4 Old 02-02-2012, 06:54 PM Thread Starter
Nereussailor
I bought a set of gauges a while back, and have been researching here to find the best place to install the sending unit for a mechanical temp gauge. It came with a 3/4" fitting that is supposed to thread into the block or intake manifold. My manifold doesn't have a 3/4" hole for the fitting that I can find. I did find a plug on the bottom side of the intake manifold that I think is 3/4" but I'm not sure and it's hard to get at. Does anyone know if that plug goes into the water jacket, or into the exhaust run? I've read about putting a fitting in the heater hose near the thermostat, but really don't want to cobble something up. If I bush the fitting down to fit in the block, I can't see where it would get enough flow into it to get an accurate reading. Any other suggestions?
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #2 of 4 Old 02-02-2012, 07:05 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
You might be able to remove the CTO if you're not using it. It is a temperature-activated valve for the vacuum system. Here's an explanation.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #3 of 4 Old 02-03-2012, 07:22 AM Thread Starter
Nereussailor
I'm not using that plug so I tried that spot, but it's too small. I'd bave to make an adapter to hold the fitting, but I'm thinking that because it would stick out so far that it wouldn't give an accurate reading because of lack of coolant flow. If I could get a camera up under the manifold, I could get a pic of the plug I'm talking about. I'll try today.
post #4 of 4 Old 02-03-2012, 07:25 AM
scoutboater
1974 CJ5
I opted for the aftermarket electronic temp gauge in mine. They come with a smaller sensor, and it just barely fits in the stock location of the I6 right next to the thermostat.
I know you already bought a gauge, but if it comes down to it, would you be willing to take it back where you got it and trade it?
scoutboater is offline
need help finding gm 151 temp sender rodjr Jeep CJ Forum 5 08-08-2011 06:33 PM
Ohms on temp sender?? stvincnt Jeep CJ Forum 1 06-29-2010 05:43 PM
Location of temp sender and oil pressure sender on 360 r2keeper Jeep CJ Forum 2 01-02-2010 10:36 AM
Temp sender, Could it be bad?? Fuzz21 Jeep CJ Forum 17 10-16-2008 11:19 AM
cj temp sender unit, where from? Popol Jeep CJ Forum 0 06-12-2003 05:20 AM
