Mechanical gauge hook up questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Mechanical gauge hook up questions
Dana 30/ Dana 44 Chromoly shaft Kits- ECGSFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201
Unread 07-09-2014, 01:04 PM   #1
jeepjerryp7m8
1982 CJ8
Just bought a set of Auto Meter oil and water temp gauges and quite honestly I haven't installed a set of these things in a long time.
On my 258 oil sender I have an electrical sender and a small black "can" with one wire coming from it, which one do I replace with the new fitting?
Also where does everyone recommend putting the water temp sender, I have a vacuum switch fitting on the intake from leftover emissions stuff, Use that port?
Thanks,
Jerry
jeepjerryp7m8 is offline   Reply With Quote
Unread 07-09-2014, 01:10 PM   #2
Varnish
Varnish's Avatar
Assuming your '82 is similar to other 258s I've seen, the larger, usually bell shaped, is the oil sender for the electrical gauge you can replace with the mechanical fitting. The smaller oil thing is a low pressure cutoff switch so you can leave that.
Temp is usually at the back of the head on driver's side - very small sender stock.
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote
Unread 07-09-2014, 01:34 PM   #3
jeepjerryp7m8
1982 CJ8
Just found the stock temp sender, no dice, I have a mechanical temp gauge with the big bulb on the end.
Unread 07-09-2014, 01:40 PM   #4
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
I was able to pull a steel pipe plug out of the aluminum Performer intake manifold (thanks for nothing PO) in a forward water jackon on my 360, it was deep enough for that bulb/sender. Hopefully you'll find a port on your 258.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline   Reply With Quote
Unread 07-10-2014, 11:00 AM   #5
jeepjerryp7m8
1982 CJ8
Gauges installed and working. Oil pressure was straight forward and I have 30 psi at warm idle and 55+ at cruising speed.
Temp was easy also, used the port at the front of the intake just below the heater hose. Temp pops up to 190* and stays there. I went on a short shake down and when I got home an idled in the drive for a few minuets and the needle didn't move a bit.
Its really nice to know what is going on.
BTW the stock oil pressure gauge was off by 15-20psi.
Unread 07-10-2014, 12:31 PM   #6
John Strenk
John Strenk's Avatar
1976 CJ5
Well it is 32 years old. In gauge years it's 96 years old.
John Strenk is offline   Reply With Quote
Unread 07-10-2014, 02:50 PM   #7
turbogus
1978 CJ5
Right on John
Unread 07-10-2014, 03:05 PM   #8
Unretarded
Unretarded's Avatar
1963 CJ5
Hopefully you got the copper line for the oil pressure......the plastic line gets brittle pretty fast, not to mention will melt etc.
Many many leaks/ problems with the plastic line.....
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline   Reply With Quote
Unread 07-10-2014, 03:23 PM   #9
jeepjerryp7m8
1982 CJ8
Oh yeah! Zero trust for the nylon tubing that came with it.
Unread 07-10-2014, 03:29 PM   #10
Tigerjeep79
Tigerjeep79's Avatar
1979 CJ7
My gauge came with a plastic line. I got a copper one from Jegs, and put a loop in it to handle flex. You have to look for it, but it's there.
Tigerjeep79 is offline   Reply With Quote
Unread 07-10-2014, 05:46 PM   #11
John Strenk
1976 CJ5
And notice the loop in the line also. I think that is important.
It allows for engine movement without straining the line.
Unread 07-10-2014, 06:17 PM   #12
jeepjerryp7m8
1982 CJ8
Yup. Looped the line and used a grommet. Wrapped the line in one turn of duct tape to provide a little extra protection.
Unread 07-10-2014, 10:57 PM   #13
80cj
80cj's Avatar
1980 CJ5
I used a Sunpro copper tubing kit to install my Autometer mechanical oil pressure gauge. A complete kit with all the necessary fittings.
80cj is offline   Reply With Quote
Unread 07-11-2014, 06:15 AM   #14
82JeepCJ7
1982 CJ7
I used the plastic line that came with the gauge just to get the gauge installed and test its operation, then I replaced the line with a braided stainless steel line from Autometer.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
