mech. fuel pump not pumping? - JeepForum.com
post #1 of 14 Old 09-29-2013, 04:03 PM Thread Starter
willierat
1980 CJ5
I have a 1980 CJ5 that I've been trying to get running. I put a new fuel pump on it and cleaned the carb. Drove it around the yard several times, sat and idled revved everything seemed great. Drove it next door to show my Uncle and it died. No fuel to the carb! Is there anything I could have done wrong while installing it(seemed simple enough) or did I just buy a BAD pump. Is there anything that could happen with the eccentric that operates the pump? Now I'm considering an electric pump. Yay or nay. If so what should I look for. I am not a troubleshooter but I can take stuff apart and put it back together, most of the time
willierat is offline
post #2 of 14 Old 09-29-2013, 07:54 PM
Spieg8
1984 CJ8
It's possible that the eccentric is worn out, but not likely (you can inspect it through the hole when you remove the pump.. look for deep grooves). It could also be that you purchased a bad pump (again, unlikely, but possible). I would be looking for an obstruction in the fuel system somewhere. Could be a clogged filter, kinked line, plugged vent, or blockage at the pickup in the tank. An electronic pump is not a bad thing to have, but I would resolve the current problem before making modifications. Good luck
Spieg8 is offline
post #3 of 14 Old 09-29-2013, 11:48 PM
BagusJeep
1981 CJ7
It could be dry rotted / cracked / holed hose on top of the tank. There is a section from the fuel sender to the fuel line, about 2 foot long, that is prone to this.
Your pump may be working fine and just sucking air.
Have you tried connecting the pump inlet to a jam jar of gas?
Have you tried sucking petrol from the fuel line? Yuck.
PS I am not a fan of electric pumps, just one more thing to go wrong and another expense. The mechanical pump with the 3 way proper fuel filter and tank return work fine.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 14 Old 09-30-2013, 07:50 AM
Balvar24
1979 CJ7
If you're tank is rotten, you could be getting rust in the pump and screwing it up. I've had it happen to mine before.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #5 of 14 Old 09-30-2013, 08:53 AM
keith460
Jeep. There's Only One
keith460's Avatar
A 1980 Jeep now has a fuel system that is 33 years old if it is all original. Start from scratch and drop the tank and look for rust and other debris inside of tank. Check all the fuel lines for rust and corrosion and replace as necessary.
Your fuel system may need a complete overhaul. I know mine did!
1984 CJ-7 Renegade
keith460 is offline
post #6 of 14 Old 09-30-2013, 12:56 PM
danielbuck
1946 CJ2
I just had this issue on my 46, it was a loose fuel line connection inbetween the engine and the tank, it was just sucking air.
danielbuck is offline
post #7 of 14 Old 09-30-2013, 02:43 PM
LumpyGrits
Check you fuel lines and clamps.
You either have a hard blockage in the main feed line. OR you are suc'n air because of poor lines/connections.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #8 of 14 Old 09-30-2013, 08:49 PM
thantos858
1974 CJ5
I would replace all the rubber lines, fuel filter and then try it all again.
thantos858 is offline
post #9 of 14 Old 09-30-2013, 08:57 PM
seabass1858
1983 CJ7
I did the overhaul. with 500$ master rebuild and 600 in machining I opted out for new fuel system and I flushed the steel lines which were already in good shape.
seabass1858 is offline
post #10 of 14 Old 10-01-2013, 08:57 AM
LumpyGrits
Remove the gas cap and use compressed air to blow the main line out.
You should hear the bubbles in the tank, if the line is clear.
LG
post #11 of 14 Old 10-01-2013, 09:32 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
FYI, new (reman'd) mechanical fuel pumps can be bad right out of the box. I had to return 2 NAPA pumps before I got one that worked.
It's an easy test. Just disconnect the fuel line from the carb and stick it in a separate container. Then crank the engine and see if you get a steady stream of fuel from the line. If it comes out bubbly, then you have a leak somewhere upstream. If it doesn't flow at all, then the pump is probably bad, or you have a major obstruction. If it's the latter, you can further isolate the problem using Bagus' suggestion.
Good luck,
Matt
Matt1981CJ7 is offline
post #12 of 14 Old 10-01-2013, 10:04 AM Thread Starter
willierat
1980 CJ5
Thanks guys, I'm gonna try the container of gas today.
post #13 of 14 Old 10-01-2013, 05:44 PM Thread Starter
willierat
1980 CJ5
So I run a hose into a gas can, turn the engine over, nothing. Take the pump back off try it manually by pushing the lever by hand, gas to the sky! I can't see how I could be installing it wrong since it did work one time. I've reinstalled it like 20 times Made a block off plate so tomorrow the pump goes back and I'm buying a universal electric.
post #14 of 14 Old 10-01-2013, 06:29 PM
BagusJeep
1981 CJ7
When you install it the lever on the end is pushed down by the lobe on the camshaft. This means it is not a drop in and bolt up operation, it needs some pressure applied.
Do you feel that pressure when you install?
If not have you got a small mirror and flashlight to look into the hole and check out what you are seeing?
