Measuring for shocks? - Page 2 - JeepForum.com
post #16 of 20 Old 11-16-2011, 07:06 PM
Area.3.Fiftyone
Forklift is the way to go. No guessing at droop and it will allow you to set your bumpstops precisely after installing a lift.
Without stuffing the wheel how else would you know where to set the bumpstops?
This method (or a ramp) lets you see exactly what you need.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #17 of 20 Old 11-16-2011, 09:49 PM
Renegade82
1982 CJ7
I hear what your saying but I don't have a forklift or an articulation ramp. I guess maybe I didn't fully explain the basis for my inquiry. I'm talking about a frame off restore with a new suspension. I'll be putting on OME springs for a yj, which flex more than most. I want to be able to use the whole range of available flex. The current plan is to get Superlift shocks and based on 4" of lift, the rears have a range of 15 1/2" - 26", a 10 1/2" range; and the fronts are 13 1/4" - 21 1/2", an 8 1/4" range. I want to make sure these will work before I order them, so I need to figure this out during the build. I agree the best way to determine the bumpstop length is to use a ramp or forklift once it's all together, but I won't have that luxury till it's all put together. Hence my initial question.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #18 of 20 Old 11-16-2011, 10:36 PM
Area.3.Fiftyone
Just wait and flex it out when you are done then. That is really the only way to get it right.
Any other way is a crap shoot and you would be guessing at it and most likely limiting the amount of flex it is capable of.
What is the hurry in putting shocks on it now?
post #19 of 20 Old 11-17-2011, 06:51 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Renegade82,
You don't need a forklift, or an articulation ramp, to measure the range of spring movement. A floor jack works just fine.
Alternatively, you can benefit from my experience with the same OME springs you are using, and go with the OME N95 long travel shocks all the way around.
Matt
Matt1981CJ7 is online now
post #20 of 20 Old 11-17-2011, 09:16 AM
Renegade82
1982 CJ7
Well to get both extremes I'll also need to compress them too, that's why I was thinking of the hi-lift used in a clamping setup. While OME shocks would be nice, I'm not looking to spend $90+ a shock right now. Do you know what the extended and collapsed lengths are for that particular shock? ARB/OME website doesn't even list parts for Jeeps, only wranglers and cherokee's. 4WD's page says "This shock measures 23.38 extended length and 14.13 compressed length." But it also says it's for a 2.5" lift, where mine is closer to 4". I also noticed they have a different part number listed for the superlift shocks than Superlift's site does, so again it comes down to misleading info on websites and the need to call them for details!!
On a full flex, how tight are your stock brake lines?
measuring backspacing on your wheels hookntail Jeep CJ Forum 2 02-25-2009 08:55 PM
pinion angle measuring atomicflatulenc Jeep CJ Forum 0 06-12-2008 07:09 AM
What Shocks/How R Shocks Suppose to Work? CJSAMM Jeep CJ Forum 5 09-26-2007 12:42 AM
Measuring the Caster caxmach Jeep CJ Forum 10 02-12-2007 05:25 PM
Measuring lift ClarkGriswold Jeep CJ Forum 2 10-23-2006 08:09 PM
