MC2100 Jet survey...what do you run? - JeepForum.com
post #1 of 14 Old 11-07-2009, 04:23 PM Thread Starter
Olrev
1981 CJ7
For those of you who run the MC2100 on your 258, I'm curious if anyone runs bigger jets (than the recommended 47-48's). I tried 47's back a while ago and it felt very sluggish. Currently, I'm running 50's and I may try 52's. I'm not too concerned about gas milage, and my plugs look nice and tan.
So anyone else out there satisfied with 1.08 venturi plus 50 or bigger jets?
81CJ7, 258, MC2100, TeamRush'd, 3"lift, 34x10.50TSL's, 3:31gears, Scrambler cab
Olrev is offline
post #2 of 14 Old 11-07-2009, 05:00 PM
wm69
That's weird. I'm running 47's and mine's running a bit rich. I've got some 46's and thought I might try to swap ONE 46 in and leave one 47 in to see if that helps. Mine's not bad, but it makes me stink when I drive it.
Now my weber equipped Jeep, that thing is blowing black smoke. Gonna take it off tomorrow to put a kit in there and rejet it as well.
wm69 is offline
post #3 of 14 Old 11-07-2009, 07:44 PM
Supertrucker
1979 CJ5
I'm running 49's and it runs rich. My idle mixture screws are 1 turn out and my accelerator pump linkage is in the 2nd hole from the top. Even with it running a little rich, I love this carb.
Supertrucker is offline
post #4 of 14 Old 11-08-2009, 06:34 PM
78treehugger
1980 CJ7
#47 jets here and running rich. I'm running the 1.14 venturi since that size was recommended from the seller on e-bay that I bought it from.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #5 of 14 Old 11-08-2009, 11:51 PM
CJ8Extreme
1983 CJ7
I'm running 51.5 custom made jets here. I made them myself because I got tired of buying bigger jets. Started with #46 and worked my way up. It ran lean until 50 and then I stepped it up to 51.5. I am happy with the plugs so far.
CJ8Extreme is offline
post #6 of 14 Old 12-01-2009, 08:49 PM
noriegaramon
Iv'e notticed a lot of people looking for jets for this carb, took me a while to find them too,
Here's a good source:
MOTORCRAFT/FORD/AUTOLITE MAIN JETS
Saludos from Cabo San Lucas!
noriegaramon is offline
post #7 of 14 Old 12-01-2009, 09:43 PM
MoC
The venturi size will also cause the jets to different from person to person. I run a 1.08 with 47 jets and am rich.
MoC is offline
post #8 of 14 Old 12-01-2009, 09:47 PM
VACJ7
VACJ7's Avatar
As well as altitude. I am about at sea level and was rich with 47s and 1.08 venturi. Running 46s now and it is way better! Plenty of power and get up and go.
VACJ7 is offline
post #9 of 14 Old 12-02-2009, 05:29 AM
starfire340
1983 CJ7
1.08 and 47's here in Wisconsin...nice brown plugs couldn't be happier!
starfire340 is offline
post #10 of 14 Old 12-02-2009, 08:16 AM
ricewt
1979 CJ7
running a 2150 1.21 venturi with 52 jets. Still runs a little rich but works great as a DD, not so much on the steep steep hills.
ricewt is offline
post #11 of 14 Old 12-02-2009, 08:21 AM Thread Starter
Olrev
1981 CJ7
Wow...is that on the 258?
Olrev is offline
post #12 of 14 Old 12-02-2009, 08:34 AM
ricewt
1979 CJ7
lol, yeah. I only put it on there because I happen to have it from my old 78 bronco. I have a 1.08 now, just havent put it on. The 1.21 can be tuned to work. Though few, some have done it successfully. Mine is "sort of" successfull
ricewt is offline
post #13 of 14 Old 12-02-2009, 08:56 AM
Blthomas
Blthomas's Avatar
1979 CJ7
About sea level also, maybe a bit higher as I'm west of NoVA. 47's and 1.08. Running the HEI/TFI hybrid so maybe the fat spark helps to keep it from running rich.
1.08 47's and pretty happy so far.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #14 of 14 Old 12-19-2009, 10:12 PM
noriegaramon
Hi, I'm about to buy some Jets myself, has anybody bought them from these guys:
Or where do you guys recommend?
Thanx!
MC2100 on 360 egabriella Jeep CJ Forum 5 11-08-2007 07:09 AM
New MC2100 ishcak Jeep CJ Forum 9 08-12-2006 12:39 AM
CA MC2100 Help KD6QZX Jeep CJ Forum 3 07-26-2006 05:56 PM
a little off topic.. Gas Price survey... knowlwk@snowhill.com Jeep CJ Forum 28 03-12-2003 06:15 PM
CJ intake manifold survey Brendan Jeep CJ Forum 2 01-26-2002 10:45 AM
