MC2100 install help - Page 2 - JeepForum.com
post #16 of 19 Old 04-25-2013, 03:36 PM
Hylke
Hylke's Avatar
1978 CJ7
Look for Jeephammers posts on wiring up the manifold heater with a relay. So yes, the red wire in the first picture is the 12 volt source wire. The green wire might be the temperature switch wire: if the manifold has heated up well enough, this switch will ground to the engineblock and thus switch off the relay.
Hylke is offline
post #17 of 19 Old 04-25-2013, 08:24 PM Thread Starter
adrose211
Alright, thanks!
adrose211 is offline
post #18 of 19 Old 04-25-2013, 10:21 PM
86cj74.2L
86cj74.2L's Avatar
In the picture that shows the choke wire you can see a relay in the wire harness. That is the relay that operates the heater under the intake.
86cj74.2L is offline
post #19 of 19 Old 04-28-2013, 03:29 PM Thread Starter
adrose211
Alright, I'll stuff 'em both up out of the way.
Thanks!
