mc2100 carb - JeepForum.com
post #1 of 13 Old 10-27-2012, 07:31 PM Thread Starter
weatherford7663
1983 CJ5
mc2100 carb
Just ordered one off ebay for my 258 inline. Hope it works any advice?
weatherford7663 is offline
post #2 of 13 Old 10-27-2012, 07:38 PM
warrior1670
Mine is great! Good choice.
warrior1670 is offline
post #3 of 13 Old 10-27-2012, 07:42 PM
cmu2Liter
Love mine...easy to install and adjust, are you going to nutter it at the same time?
Firefighter...Now and for Eternity!
cmu2Liter is offline
post #4 of 13 Old 10-27-2012, 07:42 PM
skizriz
1978 CJ7
You'll need an adapter plate to bolt to your intake. I used a Mister Gasket from Advance Auto. Part No. 1937. $20 or so.
A way to adapt your air cleaner, the Jeeps is 2 5/8" (?) and the MC 2100 is a 5 1/2" (?). I just bought a 9" round air cleaner assembly and made life easy on myself. Another $20 or so at Advance.
A new throttle cable. One from a CJ with a 304 will snap right in to your firewall, and be the exact length. Some make a bracket at the carb to hold the cable, some don't. I didn't, and see no problems with it. Another $20 or so at advance.
skizriz is offline
post #5 of 13 Old 10-27-2012, 07:46 PM Thread Starter
weatherford7663
1983 CJ5
Already did the nutter by pass and team rush upgrade
post #6 of 13 Old 11-02-2012, 06:45 PM
78treehugger
1980 CJ7
I hope u got it from a good source on there. When I got mine it was the wrong size and way out of adjustment and jetting was way off even if it was the right size. And the guy wouldn't repsond to my e-mails. After I got one from a junk yard and rebuilt it I love mine. Good luck.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #7 of 13 Old 11-03-2012, 09:36 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Make sure you use the correct adapter plate and gaskets. I would use a very thin amount of RTV to ensure you get an air-tight seal between the manifold and adapter plate. You don't want any vacuum leaks.
Know how you'll be handling the throttle linkage, as there are a couple of ways to do it (keep the original down pull, or modify to use back pull).
Make sure you have a new fuel filter and it's oriented correctly with the vent line on top.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 13 Old 11-03-2012, 10:24 AM
Turtle71
1983 CJ7
Ken,
Is the throttle linkage/bracket available from that eBay seller or elsewhere? I haven't been able to find it.
My 83 CJ7 Build:
Turtle71 is offline
post #9 of 13 Old 11-04-2012, 11:49 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by Turtle71 View Post
Ken,
You might email the Ebay guy. Here's his profile on Ebay.
I think most people fabricate their own rigs, though. My MC2100 is set up for down-pull and has a "T" bracket (mending plate, used for woodworking) screwed to the original throttle arm, and there's a throttle linkage ball screwed to the T plate. The original Jeep throttle linkage pops right onto that ball. I think I ended up cutting the linkage and rotating one end 180* and welding it back together. It seemed to fit better and work more smoothly in that orientation.
Look at this Google Image search to see what other people have built.
Ken4444 is offline
post #10 of 13 Old 11-04-2012, 01:27 PM
davegt
1983 CJ5
If you ordered from the Ebay guy mentioned in above post...you have nothing to worry about...he includes everything with great instructions...best upgrade i made..
davegt is offline
post #11 of 13 Old 11-04-2012, 02:39 PM
warrior1670
I got my carb from him! I'm very happy, great service after the sale!
post #12 of 13 Old 11-04-2012, 04:12 PM
Turtle71
1983 CJ7
Thanks for the tips!
My 83 CJ7 Build:
Turtle71 is offline
post #13 of 13 Old 12-04-2012, 06:17 PM Thread Starter
weatherford7663
1983 CJ5
MC 2100 carb
best thing i have ever done!!!!!!!!!!!!!!!!!!
