Quantcast MC 2100 Fine Tuning - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MC 2100 Fine Tuning
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 12-05-2007, 11:53 AM   #1
wswartzwel
MC 2100 Fine Tuning
I recently replaced the stock carb. on my 81 CJ7 Laredo 258 6 cylinder with
an MC2100 (108 stamped in the carb body) I do very little off roading, and this is my daily driver. I was getting 15-17 mpg with the stock carb, but it ran like crap and was hard to start.... Perhaps I should have just rebuilt the original carb, but after seeing the rave reviews here on the MC2100 swap, I figured I would just go that route. I got a carb from a friend for free, rebuilt it, got the adapter plate, and did the swap. The jeep starts and runs great... Just bump the key and it starts and idles smoothly. My gas mileage has dropped to 13 mpg however.. The main jets in the carb were stamped # 57 if I remember correctly. Has anyone experimented with different jets? Is it possible to adjust the metering rods on this carb? How about lowering the float level?
Thanks so much,
Bill
wswartzwel is offline   Reply With Quote
Old 12-06-2007, 11:29 AM   #2
CJ5_Fan
1980 CJ5
Thanks so much,
Bill
I would verify the jets... for that size throat (108) you should be running 44 to 46 not 57s. Also, make sure the powervalve you have in your carb is matched to your current motor HG levels or your MPG will suffer because the enriichment circuit will be open by default all the time.
1980 CJ5 Renegade with 304 v8
Click HERE to check out my CJ5 restoration project page
CJ5_Fan is offline   Reply With Quote
Old 12-06-2007, 01:21 PM   #3
motojoe
1982 CJ7
"HG level" ???
I get about 10 MPG with my MC2100(108) with my 258 I6 Auto.
Motojoe
C.O.R.E.
Dirtbike, Motocross
and ATV School
www.coremxschool.com
1982 CJ-7
Jamboree Edition #511
motojoe is offline   Reply With Quote
Old 12-06-2007, 03:24 PM   #4
CJ5_Fan
1980 CJ5
Originally Posted by motojoe
"HG level" ???
The HG level is the vacuum measurement. Most vehicles have a consistent vacuum reading at idle, and another under load. The powervalve is rated in HG also. You want to ensure that whatever you constant load HG level is, the Powervalve is set 2 below. That way your dont have it in the open position until you step on the gas aggressivley and force a drop in vacuum that signals the enriment circuit (via the powervalve opening) to exponse its ports and therfore enrichen the mixture.
Old 12-06-2007, 07:52 PM   #5
wswartzwel
I replaced the power valve with a new one when I rebuilt it.. I did not see any adjustment... Could you explain how to set it? I have Mercury guages so getting readings should not be a problem.
BTW Thanks so much for taking the time to respond.
Old 12-06-2007, 10:26 PM   #6
wm69
You're running jets that are too big. You should check your vacuum at idle, divide that number by 2, then subtract 2 from that number.
My vacuum reading was 23, divide that by two and I get 11.5, subract two from that and I got a 9 holley power valve at the local oreillys. Then I discovered that I had a two stage power valve....
Anyhow, I'm in fayetteville and I'm running 47's and still running a bit rich, so if you're in conway and running 57's your jets are waaaay to big. Swap your jets to 46's or 47's, check your vacuum at idle, get a new power valve (they aren't adjustable, but they are only about $7 for a new one) and then you should see an improvement.
85 CJ7 258, borla header, jacobs ign, weber carb,optima batt, 135 amp alt, agr super box 2 & pump, T5 w/ B&M shifter, centerforce 2, superior 1 piece axles, warn hubs/ XD8000i, 2.5 in lift, 31" BFG MT
85 CJ7 "wife's ride" 258, A/C, T176, superwinch hubs, 3in lift 31" BFG AT/KO
wm69 is offline   Reply With Quote
Old 12-07-2007, 07:52 PM   #7
wswartzwel
Thanks So Much!
My Jeep sees Fayettville ocassionally, when visiting my daughter at U of A.
Old 12-07-2007, 11:26 PM   #8
wm69
Is she hot?
Just kidding. I'm married with 2 and 4 year old girls. I DREAD my girls getting older, and can't even fathom then in college.
They've each already picked out one of the Jeeps that they think are theirs.
Anyhow, take a vacuum reading at idle to figure out what power valve you need, I'd try some 47's as far as jets go, and then you can fine tune with your mixture screws and that thing should run like a top.
Old 12-07-2007, 11:33 PM   #9
wswartzwel
Where would you suggest I go to buy Jets??? I don't think local autoparts stores carry them.
Yes your little girls will grow up... She took my bronco... I told her sister that my jeep was off limits
Old 12-08-2007, 01:48 AM   #10
OldSailor
1977 CJ7
You should be able to get jets at any decent auto parts store, like NAPA. If you don't have any local, you can order them from Summit or Jegs.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
