mc 2100/2150 vs. Weber 38 DGES - JeepForum.com
post #1 of 8 Old 08-21-2013, 01:11 PM Thread Starter
shadoow
i've read a lot of posts on these carbs and either seems to be good. I'm looking for someone that is familiar with both as i'm wondering which would be easiest to change between low and high elevations. I live at low elevation, but we go to higher elevation (8000-12000 ft.) in the summer. I would like to use my jeep in both situations. Jeep has a 258.
shadoow is online now
post #2 of 8 Old 08-22-2013, 08:31 AM Thread Starter
shadoow
anyone ??? maybe someone that's familiar with retuning either of these carbs for elevation change??
post #3 of 8 Old 08-22-2013, 08:50 AM
swatson454
1983 CJ7
I've been watching this one for someone who has done both carbs. I know a Weber 38 would go from a 145 main jet down to a 135 or maybe even a 130 and the jets are pretty easy to change. You'd need to take the idle jets down to 45s as well. Those are super easy to swap out.
I have no idea what's needed on an MC but Webers have quite a bit of tuning available with separate idle jets.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #4 of 8 Old 08-22-2013, 10:14 AM Thread Starter
shadoow
thanx for the info swatson. To change the weber jets as you described does the carb have to be removed from the intake manifold??
On the MC carb my understanding is the jets and likely the power valve has to be changed and changing the power valve requires removal of the carb as it's on the bottom. Can someone verify??
post #5 of 8 Old 08-22-2013, 10:30 AM
swatson454
1983 CJ7
No but the top of the carb has to come off. It's quick and easy with the exception of that tiny c-clip on the choke plate. It comes off really easy but likes to play hide-and-seek.
The idle jets are located on the side of the carb and can be swapped out in no time with just a screw driver.
I can't imagine an MC needing a power valve swap
Shawn
post #6 of 8 Old 08-22-2013, 11:22 AM
jeepwhore
Shawn
Me either. Changing the PV will change the point in acceleration at which the extra fuel is let into the system but unless the OP putts around at 1/4 throttle all day it will still do it's job.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #7 of 8 Old 08-22-2013, 02:57 PM Thread Starter
shadoow
OK, sounds like i'm wrong on the MC power valve so that's good to know, appreciate it.
Can the jets on the MC be changed similarly to the Weber??
post #8 of 8 Old 08-23-2013, 04:21 AM
razor2264
1979 CJ5
I ran a mc 2100 for a couple years. I put #47 jets in and it ran well. To change the jets, take off the top and they are in the bottom of the bowl.
razor2264 is offline
