Maybe a CJ guy can help... - JeepForum.com
post #1 of 24 Old 09-18-2011, 07:01 PM Thread Starter
csrcn2
I know this is the cj forum but I think someone may be able to help me. 89 YJ 258 with MC2150 and nuttered. 48 jets and 1.08 venturi. Ported vac to reman dizzy.
Problem with part throttle hesitation. Normally 1100 to 1500 rpms. If I start below and accelerate through it goes fine. Anywhere in between she wants to stall, if I pump the throttle either immediately before I know it will stall or right when it begins to she recovers and goes fine. Tried tuning the timing advanced and retarted also adjusting he advance curve with no success.
No vac leaks that I can find. Been trying to get this right for months.
csrcn2 is offline
post #2 of 24 Old 09-18-2011, 07:16 PM
dzltech1
1979 CJ7
adjust your mixture
ASE Master Diesel,Heavy/Medium truck technician,ASE Master Automotive Technician.
EVT Master Fire Apparatus Technician,
Caterpillar,Cummins and Detroit Diesel Certified
Certified Ford Diesel and Automotive Master Technician.
dzltech1 is offline
post #3 of 24 Old 09-18-2011, 07:17 PM
gojeepin
1983 CJ7
It could be a problem with the carb's accelerator pump or lack of the proper timing advance.
When adjusting the timing curve, did you adjust the vacuum cansister?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 24 Old 09-18-2011, 07:17 PM
BlueRubiconrich
get a webber or Ford 2100
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 24 Old 09-18-2011, 07:20 PM Thread Starter
csrcn2
Accel pump shoots two great streams of fuel, timing is 8* btdc, and I set the mixture screws with a vac gauge. And yes it was adjusted by the vac canister.
csrcn2 is offline
post #6 of 24 Old 09-18-2011, 07:21 PM Thread Starter
csrcn2
Ummm that is the Ford 2100, and i'll take a weber if ya want to buy it for me! ;b
csrcn2 is offline
post #7 of 24 Old 09-18-2011, 07:35 PM
gojeepin
1983 CJ7
It sounds like you aren't getting the advance you need until the mechanical advance starts.
gojeepin is offline
post #8 of 24 Old 09-18-2011, 07:42 PM Thread Starter
csrcn2
So you think I need to give it more vac advance in the lower rpms? 31" tires on stock axle
csrcn2 is offline
post #9 of 24 Old 09-18-2011, 07:46 PM
gojeepin
1983 CJ7
Perhaps. The vacuum advance is going to respond to combination of butterfly position and RPMs. At lower RPMs, butterfly position is the main influence.
gojeepin is offline
post #10 of 24 Old 09-18-2011, 07:51 PM Thread Starter
csrcn2
So the butterflies aren't opening fast enough? That's not adjustable is it?
csrcn2 is offline
post #11 of 24 Old 09-18-2011, 07:53 PM Thread Starter
csrcn2
Do you think an increased jet size might aid them?
csrcn2 is offline
post #12 of 24 Old 09-18-2011, 08:47 PM
Skerr
Jets are cheap and easy to change, so you might try 50s, but I think you're okay with 48s. I want to say I'm at 10* on my timing with great response, however I am running the 2100 with 1.21 venturi.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #13 of 24 Old 09-18-2011, 08:52 PM Thread Starter
csrcn2
So the larger venturis means your moving more air. Correct?
csrcn2 is offline
post #14 of 24 Old 09-18-2011, 09:01 PM
BagusJeep
1981 CJ7
The ported vacuum source on the carb may not allow you to wind in enough vacuum at low load levels and this may be what you are seeing in the transition. The manifold vacuum on the other hand would give too much.
A NLVR valve was fitted to many 258s of the period and this may be what you need to smooth out the two sources. Have you got such a device in the pile of bits you took off?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #15 of 24 Old 09-18-2011, 09:21 PM
lucdog
lucdog's Avatar
1980 CJ5
No, and I'm not 100% on this, but the engine will pull the air it needs, and 1.08 venturis are the best size. the 1.21 venturis work fine, and IIRC when air moves thru the 1.21 venturis its not at the same velosity as with the 1.08.
I'm not real sure on this either but, the velosity of the air moving thru the venturis pulls fuel from the idle circut in a siphon effect. At least this is how I understand it.
I think I would try changing your vaccume advance to straight manifold. instead of ported, see what happends.
On edit, Thanks Bagas. never heard of one of these. I must be one slow typist, took me at least 22 minutes to type this.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
