Maybe a 1985 CJ7? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Maybe a 1985 CJ7?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSave on Warn Winches and TENOFF Promotion!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread Yesterday, 06:38 PM   #1
jandbkrause
Maybe a 1985 CJ7?
How can I tell what I own??? I have a CJ/Scrambler 1971-86 Repair Manual and in all three pictures none of them match my Vehicle Identification plate. I have the VIN but then I have more numbers below it. J235488 then below that I have 4C 11 1BA. Has anyone ever seen this and can you tell me what year and make I have??? Thanks for the help.
Extreme Rookie,
Jason
jandbkrause is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:19 PM   #2
LobstahJeep
Post the VIN on the dash...
LobstahJeep is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:32 PM   #3
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This page has VIN decoding information for CJs from 71 to 86:
http://www.jeep4x4center.com/knowled...-1971-1986.htm
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:43 PM   #4
Mr. Boh
4C is your color code, which is Ice Blue Metallic. That was only offered from 84-85 so that narrows down your years right there.
1BA is your trim code, which is low back black vinyl seats. That trim code was used from 85-86.
So your guess of an 85 is probably correct. Your VIN will start 1J..............
From that we can tell you your year and trans.
Mr. Boh is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:51 PM   #5
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
Sounds like you're not looking at the VIN. The VIN will be the last line on the tag. As above .... it should be a 17 digit number starting with 1J ......
Is it snobby I don't wave at 4-door Jeeps? :)
-Scott
'81 CJ7 Rebuild ... http://www.jeepforum.com/forum/f8/my...oject-1543726/
Jeepn-n-tx is offline   Reply With Quote Quick reply to this message
