maxima to amc 20 disc brake conversion brackets blue print needed? - Page 5 - JeepForum.com
post #61 of 212 Old 03-17-2013, 09:11 PM
titanjeep
1980 CJ5
Originally Posted by poorboywithjeep View Post
Yes I'm ordering those off BESRK but don't you need the bracket off the car also or does the BESRK bracket bolt from the housing flange directly to the caliper?
You don't need the bracket off the car. The BESRK bracket bolts the caliper to the axle flange.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
post #62 of 212 Old 03-18-2013, 09:26 AM
poorboywithjeep
Ok great! Thank you!
poorboywithjeep is offline
post #63 of 212 Old 03-18-2013, 04:37 PM
hmantractors
2004 KJ Liberty
Rotors
Originally Posted by waterdowg View Post
Sorry if I gave you bad info on the rotors. It seems that this install has lots of conflicting information and what works for one does not work for others. So I looked at the specs. Guess you I can't trust those either. So my suggestion to anyone who does this swap. Check the rotors to the calipers before you leave the store. Again sorry .
FOUR DOOR ROTORS WILL NOT WORK. JUST MAKE SURE THE CALIPERS ARE CENTERED ON THE ROTORS. I HAD TO RELOCATE THE HOLES IN THE BRACKET TO MAKE THIS HAPPEN. IF NOT LOCATED CORRECT, PADS WILL WEAR WRONG-WILL NOT HAVE FULL STOPPING FORCE AND COULD LEAD TO THE PADS BEING KICKED OUT AS SOME HAVE EXPERIENCED.
hmantractors is offline
post #64 of 212 Old 03-18-2013, 05:51 PM
waterdowg
I did a lot research after I gave the info. It turns out the info was kind of right but wrong for Truck633. He purchased 84 300z calipers. Well in 84 the 300z rotors were 10.1mm. That would be the same as the Geo Tracker 2 door.
But in 87 Nissan changed the calipers and rotors. They use 20mm rotors. The Geo 4 door rotors are 17mm. If you use the 10mm on the 87/88 300z calipers they will kick when worn.
Now your idea of lowering the caliper on the bracket is awsome. I don't think I saw anyone do that, but I wonder if the 300z calipers are shorter. It would be nice to see some pic of the 300 caliper in relation to the rotor.
I think you solved the problem with the Maxima calipers.
waterdowg is offline
post #65 of 212 Old 03-18-2013, 10:32 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
I will post photos when I get home in a day or two. If I recall, the 300 calipers had a pretty good recess where they fit into the brackets, if I move the caliper down I may have to work a shim in.
Now it is killing me, I wanna go home and work on the jeep!!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #66 of 212 Old 03-19-2013, 07:10 AM
titanjeep
1980 CJ5
The mounting tabs on the 300ZX rotors are shorter, and the BESRK brackets are cut using a template for the 300ZX brackets. When I did my test fit of all the components this weekend, the pads were fully engaged on the rotor without the holes being lowered.
I hope to finish the instal and have some pictures up this weekend.
2003 KJ
1980 CJ5
1988 Wagoneer
post #67 of 212 Old 03-19-2013, 07:20 AM
CJ7ROB
My '84 Z calipers on 2dr rotors using BESRK brackets:
Driver side:
Passenger side:
CJ7ROB is offline
post #68 of 212 Old 03-19-2013, 08:55 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Best news ever!
Now just gotta get back to NM!
Truck633 is offline
post #69 of 212 Old 03-19-2013, 10:13 AM
kappa505
1980 CJ5
Truck, we live in the same city and I am doing this swap also.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #70 of 212 Old 03-19-2013, 11:32 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Cool... I will shoot you a pm when I get home maybe early next week, we can compare notes!
Truck633 is offline
post #71 of 212 Old 03-19-2013, 06:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Driver side:
Passenger side:
Sexy!!!
Now just put some Moser Engineering one-piece axles in there & it'll be really groovy!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #72 of 212 Old 03-19-2013, 06:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm cutting/bending some 3/16" tabs for the parking brake cable for Truck633. If they fit, I'll probably start cutting those to go with my Caliper brackets and maybe bump the price up to $30 shipped..
Before everyone bum rushes me with orders for those tabs, let me make sure they're gonna work first..
BESRK is offline
post #73 of 212 Old 03-19-2013, 07:19 PM
CJ7ROB
Originally Posted by Mean Max View Post
Sexy!!!
Max
Thx, yea I have the Moser 1 pc axles and new bearing kits. I'll get them installed eventually.
CJ7ROB is offline
post #74 of 212 Old 03-19-2013, 08:03 PM
jamie0921
1973 CJ5
So what's the full cost of this conversion
jamie0921 is offline
post #75 of 212 Old 03-19-2013, 08:04 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
I am in it for just under 400 with all new stuff....
Could be much cheaper with a visit to the junkyard
Truck633 is offline
AMC 20 disc brake conversion johnnypac Jeep CJ Forum 20 04-22-2011 07:38 PM
model 20 disc brake brackets jhorton Jeep CJ Forum 6 02-20-2011 11:29 PM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
