maxima to amc 20 disc brake conversion brackets blue print needed? - Page 3 - JeepForum.com
post #31 of 212 Old 01-22-2013, 07:55 PM
titanjeep
1980 CJ5
Originally Posted by CJ7ROB
The plates that Eddie (BESRK) makes are sweet..Well worth the $25 for them. They line right up with the calipers..I may have it on backwards, not sure until I'm ready to put them on.
Wish I could say the same for the ones I got off eBay... in the process of fixing the caliper holes right now. Hopefully the axel side is better.
If only I had known BESRK was making them sooner.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
post #32 of 212 Old 02-25-2013, 08:10 PM
rsegriggy
1981 CJ7
Originally Posted by CJ7ROB View Post
I just ordered the brackets from BESRK. Any benefit of one of these sets of calipers over the other? Any performance differences between the 300Zx and Maxima calipers? Thanks
Maxima
300zx
I have the 300zx calipers. You have to watch the years. There are some differences. I went through 3 different versions until I matched up a new driver side for my existing passenger side.
I found that the 4-door Tracker rotors work with the early 300zx calipers. (4 door rotors are thicker and vented.) I was using the 2 door version, but as they wore, there was enough room for the brake pad to slip out.
rsegriggy is offline
post #33 of 212 Old 03-10-2013, 06:42 AM
poorboywithjeep
how do i get a hold of BESRK to order these brackets?
poorboywithjeep is offline
post #34 of 212 Old 03-10-2013, 07:29 AM
CJ7ROB
Just send him a PM.
CJ7ROB is offline
post #35 of 212 Old 03-10-2013, 08:47 AM
78FordF150
1983 CJ7
Hey CJ7ROB, could you post up a quick list of all the parts you used for this and maybe where you got them. And what is everyone doing about emergency brakes.
Thanks
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #36 of 212 Old 03-10-2013, 09:22 AM
titanjeep
1980 CJ5
Thanks
Here is an excellent write-up by sherlocktk on how to use the stock emergency brake cable on the 300Z calipers. This is how I plan to hook them up. I am hoping to finish my installation up next week and them I can some post some pictures and let you know if I run into any issues.
http://www.jeepforum.com/forum/f8/pa...-help-1340329/
2003 KJ
1980 CJ5
1988 Wagoneer
post #37 of 212 Old 03-10-2013, 12:28 PM
CJ7ROB
Thanks
check out the last couple pages of my build thread . I listed all the parts there
CJ7ROB is offline
post #38 of 212 Old 03-10-2013, 12:40 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
I am headed to the parts store now.....
This looks AWESOME!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #39 of 212 Old 03-10-2013, 04:56 PM
titanjeep
1980 CJ5
Is there a reason that you have your calipers mounted toward the front of the Jeep? Most of the other installations I have seen have the calipers mounted angled toward the rear of the Jeep.
2003 KJ
1980 CJ5
1988 Wagoneer
post #40 of 212 Old 03-10-2013, 06:52 PM
Thbugman
1978 CJ7
Take pics, I'm ready to start this install as well...
Thbugman is offline
post #41 of 212 Old 03-10-2013, 07:17 PM
78FordF150
1983 CJ7
Thanks for the link. This is something I will be doing in the future.
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
post #42 of 212 Old 03-10-2013, 08:13 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Ordered brackets, got rotors.... ordered 300ZX calipers, but told the guy I may return them ( I order loads of parts, they said no problem) I checked the Maxima calipers and they were 45 dollars cheaper each. Is their a huge difference between the two? I am going to compare them side by side tomorrow, but if anyone has info on this, please let me know!! Also, where the backing plate gets ground down, can you still use those bolts, or do you have to replace them with longer bolts? ( I assume you use three of the original bolts through the new bracket....)
Truck633 is offline
post #43 of 212 Old 03-11-2013, 05:27 AM
waterdowg
The only difference is the rotor you use. If wou go with the 300 calipers you will need the thicker tracker 4 door rotors. The maxima calipers will use the thiner tracker 2 doors rotors.
waterdowg is offline
post #44 of 212 Old 03-11-2013, 07:08 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
uuuggh. this wasn't how I read the other post I got the two door rotors.
Truck633 is offline
post #45 of 212 Old 03-11-2013, 07:14 AM
waterdowg
Whats did you read in thr other post?
AMC 20 disc brake conversion johnnypac Jeep CJ Forum 20 04-22-2011 07:38 PM
model 20 disc brake brackets jhorton Jeep CJ Forum 6 02-20-2011 11:29 PM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
