maxima to amc 20 disc brake conversion brackets blue print needed? - Page 14 - JeepForum.com
post #196 of 212 Old 04-28-2013, 10:08 PM
titanjeep
1980 CJ5
Originally Posted by billybooster2
Any news?
Tried bleeding the way you recommended this afternoon. Only got a couple of small (pin head sized) bubbles out of each caliper, but the pedal feels better. Hopefully I can get her out for a test drive in the next couple of days. Assuming all is well I can finally finish up the parking brake cable installation.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
post #197 of 212 Old 05-04-2013, 06:18 PM
titanjeep
1980 CJ5
I am starting to wonder about the design of the mounting bracket. The current design has the rotors clocked between the 1 and 2 o'clock position on the rotors. But I think we would be better off mounting them at the 3 o'clock position. It is closer to the stock mounting position on the Nissan (as far as I can tell from my research) which should make them easier to bleed. And by slightly altering emergency brake brackets, I think that you could use the stock brake cables.
I am thinking about contacting BSERK and seeing if he could fab up some new brackets for the new mounting location. Anyone have a reason why this might be a bad idea?
Thanks.
2003 KJ
1980 CJ5
1988 Wagoneer
post #198 of 212 Old 05-18-2013, 02:22 PM
rsegriggy
1981 CJ7
Mine have to be unbolted and rotated to get them to bleed. It takes a few times. I'd like make a new bracket to rotate the caliper into a position it can be left attached and bled. I did use the stock CJ-7 e-brake cables with it.
rsegriggy is offline
post #199 of 212 Old 05-19-2013, 03:50 PM
titanjeep
1980 CJ5
Mine too. That is what first got me thinking qua out rotating them down.
How are you liking your set-up?
2003 KJ
1980 CJ5
1988 Wagoneer
post #200 of 212 Old 05-19-2013, 06:50 PM
rsegriggy
1981 CJ7
I've been very pleased with it. Took a while to get everything sorted out. The 4dr tracker rotors were the last piece that really helped. I am running a D44 in the rear, so my mounting pattern is a little different than the AMC20. I would like to make new brackets to rotate them into the position that they were on a stock Nissan. One thing to think about is switching sides with them. Not sure I have the left caliper on the left side of the jeep. They won't work if I switch them, the e-brake doesn't line up nearly as well.
How thick a plate is everyone using for the caliper bracket? Mine are made from 2 pieces of 1/4" plate welded together. I figure welding the seams and then sticking 6 bolts through it will keep everything together and make sure my welds aren't critical to safety.
post #201 of 212 Old 05-20-2013, 09:24 AM
CJ7ROB
I think mostly everyone is using 3/8" plate.
CJ7ROB is offline
post #202 of 212 Old 07-20-2013, 11:09 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
OK.....
after a LOT of trial and error (mostly error) I have changed some things around for this conversion.
I am running 35's and a 4:1 kit in my Dana 300 t-case, why is that important? because my goal is to get the rear brakes to hold when the CJ is suspended (on jackstands)
I have gathered most of the parts, however I am leaving for work and won't return for a week, when I get back I am going to start another thread, as I have hijacked the heck out of this one!!
If the results are as successful as the conversion we did on the YJ, I will finally be able to mark this conversion as complete!!
Stay tuned!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #203 of 212 Old 07-21-2013, 04:47 AM
haro504
1979 CJ7
I had a 94 mercury sable with rear disk breaks and there was a e brake setup built into it. It might be another option for you guys. It would probably need a different type of mount though.
haro504 is offline
post #204 of 212 Old 07-21-2013, 08:13 AM
titanjeep
1980 CJ5
Originally Posted by Truck633 View Post
OK.....
Stay tuned!!
Looking forward to seeing what you have done. Be sure to post a link to that thread here so we can follow along. Have a safe trip.
2003 KJ
1980 CJ5
1988 Wagoneer
post #205 of 212 Old 07-21-2013, 09:47 AM
sherlocktk
Good luck with the 4 to 1 testing. I have done that on the ground 2 wheel low (front hubs unlocked) and the front tires skid and the rear keeps chugging. In first im doing about 3200 ft pounds out of the driveshaft potentially. That times your gear ratio makes for some seriously high ft lbs to your tires. I run 4.56 x 33 so I am lower than most i my gearing. If front hubs are locked You get all 4 brakes working for you and its much easier to stall it out. I have to push really hard in 4 low to stall in 1 st gear
sherlocktk is offline
post #206 of 212 Old 07-21-2013, 10:47 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
True enough. I have a customer with a 4.2L CJ7 and an SM465 with 4.56 gears. With the transmission in 1st (granny low, 6.35:1 ratio) and the transfer case in 2HI the Jeep will not stall, and it will drive beyond the capability of the stock disc/drum brakes (not power assisted) with the engine idling.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #207 of 212 Old 07-31-2013, 12:21 AM
titanjeep
1980 CJ5
OK.....
Stay tuned!!
Any updates?
2003 KJ
1980 CJ5
1988 Wagoneer
post #208 of 212 Old 08-05-2013, 09:47 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Sorry for not getting back to this thread...
I did start another thread on my conversion... It should be said here that this conversion MAY work and only if you are running a stock setup with stock wheels... And then it is still a crapshoot!!
As for my progress with the new brackets and the GM calipers.. I can stop on a dime and give ya .08 cents change!!
It will hold the rears (suspended) in 4 low and the best thing is... NO MORE ANNOYING SQUEAK!!!!!
I took the CJ out this weekend and rode her hard both days... Flawless performance!!!
Here is the thread..
http://www.jeepforum.com/forum/f8/am...rsion-1554011/
Truck633 is offline
post #209 of 212 Old 03-15-2014, 08:05 PM
Wvuzach79
Does besrk still make these brackets or does ne one have auto cad file to download?
Wvuzach79 is offline
post #210 of 212 Old 03-16-2014, 08:55 PM
Thbugman
1978 CJ7
I don't know if he does but I have a set I'm not using. Ended up going with the TSM brakes.
Thbugman is offline
AMC 20 disc brake conversion johnnypac Jeep CJ Forum 20 04-22-2011 07:38 PM
model 20 disc brake brackets jhorton Jeep CJ Forum 6 02-20-2011 11:29 PM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
