maxima to amc 20 disc brake conversion brackets blue print needed? - Page 13 - JeepForum.com
post #181 of 212 Old 04-19-2013, 07:51 AM
titanjeep
1980 CJ5
Originally Posted by waterdowg
Well there is a mood the used Caddy front calipers, but does not get you the e-brake set. I'm not so sure the nissan pads are to small. I look at my Suburban rear pad and yes they are twice the size, but it is much heavier and designed to pull and stop 10,000 trailer.
I was always told that the front did most of the stopping power.
Here is your Caddy conversion kit. It is going to be more expensive than the Nissan conversion, but less than the SSBC one.
http://www.tsmmfg.com/2590.html
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
post #182 of 212 Old 04-19-2013, 07:53 AM
CJ7ROB
For those actually using the 300x/Maxima calipers (b/c that's what this thread is about) are you switching your proportioning valve to 4whl disc like below? I talked to these guys that I bought my booster/MC from and he said I'd want to change to this one, or would you keep the stock disc/drum one and add an adjustable proportioner? thx
http://www.ebay.com/itm/Jeep-CJ-univ...vip=true&rt=nc
CJ7ROB is offline
post #183 of 212 Old 04-19-2013, 07:59 AM
billybooster2
1983 CJ8
http://biobug.org/jeep/cj/ref/Warn-B...structions.pdf
Cadillac brake info. You just need the bracket
billybooster2 is offline
post #184 of 212 Old 04-19-2013, 08:05 AM
billybooster2
1983 CJ8
I stuck with my manual brake prop valve, no alterations
post #185 of 212 Old 04-19-2013, 09:02 AM
82JeepCJ7
1982 CJ7
I have been thinking about rotor and pad size for awhile. Although they do not offer a parking brake (what's that? Its never worked anyway...) I have been thinking about using CJ front calipers and F-150 front rotors. The F-150 rotors have a deep offset and would get the disc and caliper away from the wheel center a bit. This would allow for a simple bracket to be welded to the axle to support the caliper. In my opinion, this would be a much stronger setup with much thicker disc...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #186 of 212 Old 04-19-2013, 09:10 AM
82JeepCJ7
1982 CJ7
CJ front disc on the rear and Ford SVO rear calipers...
2000 Mustang GT rear caliper with built in parking brake.
CJ front rotor on rear with SVO caliper.
post #187 of 212 Old 04-19-2013, 09:13 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
About the only thing this "upgrade" has done for me, is let me know it is time for '60s.
Oh well, live and learn!!!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #188 of 212 Old 04-20-2013, 07:37 AM
titanjeep
1980 CJ5
I am assuming the bleeder did not perform as hoped.
2003 KJ
1980 CJ5
1988 Wagoneer
post #189 of 212 Old 04-20-2013, 09:32 AM
hmantractors
2004 KJ Liberty
Brake calipers
I like that Ford SVO caliper, I hope somebody trys it. Hey Matt heres your chance. Things improve in the auto world very quckily. It is impossible to research and to be able to know what is out there to use as a possible improvement. It takes guys who are willing to invest time and resources to find something that works. Sometimes it's a home run, sometimes not so good. Somebody will hit on the perfect solution. If you are like Matt then just don't do it. The old saying is Rome wasn't built in a day. Hopefully someone will hit on it.
hmantractors is offline
post #190 of 212 Old 04-20-2013, 12:21 PM
82JeepCJ7
1982 CJ7
As time and money permits, I am going to try the CJ front rotor/SVO option. I will keep everyone posted as I go.
post #191 of 212 Old 04-20-2013, 06:21 PM
titanjeep
1980 CJ5
I will be curious to see how this works out for you. Be sure to start a thread when you make the mod.
So, I didn't get the parking brakes hooked up today (although the cables I bought look like they will work well). But, I did take her out for a drive!
Before going out for the drive, I had my wife pump the brakes so I could watch them engage the pads on the rotor. All was good, so I took her for a spin around the neighborhood. She stops really well... once the pedal is depressed about half way. I think this means I still have air in the system (but I welcome any other opinions). I am putting the parking brake cable installation on hold so I can try bleeding them on a block of wood.
2003 KJ
1980 CJ5
1988 Wagoneer
post #192 of 212 Old 04-21-2013, 07:19 AM
billybooster2
1983 CJ8
For bleeding, try simple gravity. Make the assumption that u were a good bleeder and the lines are not the issue, its the caliper. Disconnect the lowest caliper bolt and rotate. The caliper until the nipple is at top, crack it open slightly and start rotating past vertical. Little baby bubbles will come out, no need to pump pump hold from pedal. When bubbles stop, close, reinstall, test.
post #193 of 212 Old 04-21-2013, 09:27 AM
titanjeep
1980 CJ5
Thanks... I will give that method a shot first before I try the wood block method.
2003 KJ
1980 CJ5
1988 Wagoneer
post #194 of 212 Old 04-24-2013, 07:26 AM
billybooster2
1983 CJ8
Any news?
post #195 of 212 Old 04-24-2013, 05:47 PM
titanjeep
1980 CJ5
Any news?
Not yet. Unfortunately I won't have time to work on this until Saturday. But I will post an update and let you know how it works.
2003 KJ
1980 CJ5
1988 Wagoneer
AMC 20 disc brake conversion johnnypac Jeep CJ Forum 20 04-22-2011 07:38 PM
model 20 disc brake brackets jhorton Jeep CJ Forum 6 02-20-2011 11:29 PM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
