maxima to amc 20 disc brake conversion brackets blue print needed? - JeepForum.com
post #1 of 212 Old 05-01-2011, 07:07 PM Thread Starter
jarrodblake
1978 CJ10
I am in the middle of converting my rear brakes to disc brakes. I'm using the 96 maxima brakes. I'm going to have a shop cut them for me out of 3/8, Dose any one have a blue print for the maxima brackets? I have the 300zx blue prints but they are a little different. Dose any one know what the difference is in the two brakes brackets? Can i swap out the caliper brackets and use the same caliper?
thanks in advance!
Pics of the two calipers.
maxima
300zx
jarrodblake is offline
post #2 of 212 Old 05-02-2011, 07:24 AM
aero mech
aero mech's Avatar
1980 CJ7
Here's the one I used. Should be able to print it. Hope this helps.jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #3 of 212 Old 05-02-2011, 08:33 AM
waterdowg
What Rotors are you going to use? I'm really thinking of doing this convertion since my rear Drums are shot. New drums a close to the same price as this mod.
waterdowg is offline
post #4 of 212 Old 05-02-2011, 09:51 AM Thread Starter
jarrodblake
1978 CJ10
thank you for the print out looks good and its for the maxima?^^
1984 Nissan 300zx or 96 maxima rear calipers w/ built in parking brake
New pads
1996 Geo Tracker 2 door front rotors
2 pieces of 6"x6"x3/8" steel plate for bracket fab.
post #5 of 212 Old 05-02-2011, 12:37 PM
aero mech
aero mech's Avatar
1980 CJ7
New pads
Might want to wait to drill the two caliper mounting bracket holes until you mock them up. I ended up moving the holes to better center the pads on the rotor. I also used the tracker front rotors. The bracke mounting holes are dead on. jc
post #6 of 212 Old 05-02-2011, 01:26 PM
asoude1
What size paper did you print the sketch out on?
asoude1 is offline
post #7 of 212 Old 05-02-2011, 02:09 PM Thread Starter
jarrodblake
1978 CJ10
+1 i cant get right size
post #8 of 212 Old 05-02-2011, 03:02 PM
aero mech
aero mech's Avatar
1980 CJ7
Standard 8.5 X 11. I will say that I scanned that picture into my computer after I used it. The original was a cad drawing which I down loaded from this sight. Then I had an engineer friend print it to scale. I tried to print it and had the same results as you guys. Sorry I don't know how to make it print the correct size though my picture looks correct. jc
post #9 of 212 Old 05-03-2011, 03:39 AM
waterdowg
Is this the one you used? When I print it out and take some measurements they seem to match the measurements on the picture.
http://www.abeenterprises.com/files/CJ-DiscBrake-Bracket.pdf
post #10 of 212 Old 05-03-2011, 06:00 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I just cut 2 pair of those brackets on the plasma table last night... for a buddy.
I've got the DXF files if anyone needs them. I can also do those brackets for anyone who needs them.. figure $20 per set and $5 shipping in a Flat Rate Box.. cut from 3/8". PM if interested..
BESRK is offline
post #11 of 212 Old 05-03-2011, 06:09 AM
Machinist
good deal right there!!
Machinist is offline
post #12 of 212 Old 05-03-2011, 07:26 AM
asoude1
I'll take a pair. Can you not drill the caliper mounting holes? That way i can make sure its a perfect fit.
asoude1 is offline
post #13 of 212 Old 05-03-2011, 03:23 PM
Blue83CJ7
1980 CJ7
Never heard of this upgrade, now I want to do it.. Do the brackets bolt or weld on?
Do you need to add anything like a different proportioning valve/MC for four wheel discs or is it just a simple bolt on?
Blue83CJ7 is offline
post #14 of 212 Old 05-03-2011, 06:23 PM
waterdowg
I never heard of it before. But now I want to do it. Its a out the same cost as new drums and pads. Since I have to do those soon I will do this. It looks like a bolt in, no welding and you can use the same MC and proprotioning valve.
post #15 of 212 Old 05-03-2011, 07:52 PM Thread Starter
jarrodblake
1978 CJ10
heres a good link with pics
http://jeep-forums.4wd.com/showthrea...20-disk-brakes
the brackets bolt on
AMC 20 disc brake conversion johnnypac Jeep CJ Forum 20 04-22-2011 07:38 PM
model 20 disc brake brackets jhorton Jeep CJ Forum 6 02-20-2011 11:29 PM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
