-   -   maxima to amc 20 disc brake conversion brackets blue print needed? (http://www.jeepforum.com/forum/f8/maxima-amc-20-disc-brake-conversion-brackets-blue-print-needed-1208307/)
jarrodblake 05-01-2011 07:07 PM
I am in the middle of converting my rear brakes to disc brakes. I'm using the 96 maxima brakes. I'm going to have a shop cut them for me out of 3/8, Dose any one have a blue print for the maxima brackets? I have the 300zx blue prints but they are a little different. Dose any one know what the difference is in the two brakes brackets? Can i swap out the caliper brackets and use the same caliper?
thanks in advance!
Pics of the two calipers.
maxima
http://www.autopartswarehouse.com/im...01.jpg?17Gh6aP
300zx
http://www.autopartswarehouse.com/im...86.jpg?7L3MXBD
aero mech 05-02-2011 07:24 AM
1 Attachment(s)
Here's the one I used. Should be able to print it. Hope this helps.jc
waterdowg 05-02-2011 08:33 AM
What Rotors are you going to use? I'm really thinking of doing this convertion since my rear Drums are shot. New drums a close to the same price as this mod.
jarrodblake 05-02-2011 09:51 AM
thank you for the print out looks good and its for the maxima?^^
1984 Nissan 300zx or 96 maxima rear calipers w/ built in parking brake
New pads
1996 Geo Tracker 2 door front rotors
2 pieces of 6"x6"x3/8" steel plate for bracket fab.
aero mech 05-02-2011 12:37 PM
New pads
Might want to wait to drill the two caliper mounting bracket holes until you mock them up. I ended up moving the holes to better center the pads on the rotor. I also used the tracker front rotors. The bracke mounting holes are dead on. jc
asoude1 05-02-2011 01:26 PM
What size paper did you print the sketch out on?
jarrodblake 05-02-2011 02:09 PM
+1 i cant get right size
aero mech 05-02-2011 03:02 PM
Standard 8.5 X 11. I will say that I scanned that picture into my computer after I used it. The original was a cad drawing which I down loaded from this sight. Then I had an engineer friend print it to scale. I tried to print it and had the same results as you guys. Sorry I don't know how to make it print the correct size though my picture looks correct. jc
waterdowg 05-03-2011 03:39 AM
Is this the one you used? When I print it out and take some measurements they seem to match the measurements on the picture.
http://www.abeenterprises.com/files/CJ-DiscBrake-Bracket.pdf
BESRK 05-03-2011 06:00 AM
I just cut 2 pair of those brackets on the plasma table last night... for a buddy.
I've got the DXF files if anyone needs them. I can also do those brackets for anyone who needs them.. figure $20 per set and $5 shipping in a Flat Rate Box.. cut from 3/8". PM if interested..:cheers2:
Machinist 05-03-2011 06:09 AM
good deal right there!!
asoude1 05-03-2011 07:26 AM
I'll take a pair. Can you not drill the caliper mounting holes? That way i can make sure its a perfect fit.
Blue83CJ7 05-03-2011 03:23 PM
Never heard of this upgrade, now I want to do it.. Do the brackets bolt or weld on?
Do you need to add anything like a different proportioning valve/MC for four wheel discs or is it just a simple bolt on?
waterdowg 05-03-2011 06:23 PM
I never heard of it before. But now I want to do it. Its a out the same cost as new drums and pads. Since I have to do those soon I will do this. It looks like a bolt in, no welding and you can use the same MC and proprotioning valve.
jarrodblake 05-03-2011 07:52 PM
heres a good link with pics
http://jeep-forums.4wd.com/showthrea...20-disk-brakes
the brackets bolt on
The time now is 07:09 AM.
