Max Tire Size - 84 CJ7 w/ 3" Lift - JeepForum.com
post #1 of 13 Old 03-14-2011, 03:45 PM Thread Starter
cpistorius
Howdy,
I am lifting my CJ7 with a 3 inch body lift and was curious how big I can go with new tires. I am guessing 33" tires. I am keeping the original 15" wheels.
Thanks!
cpistorius is offline
post #2 of 13 Old 03-14-2011, 03:47 PM
Machinist
i have a 4 inch rough country with 1 3/4 in boomerangs and I clear 35's without problem.I would guess you are really close to 33's
Machinist is offline
post #3 of 13 Old 03-14-2011, 03:51 PM
Jeepican
1976 CJ5
Why waste your money on a 3" Body lift? If your going to lift it save money and do it right. Otherwise leave its stock height or max body lift of 1"
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #4 of 13 Old 03-14-2011, 03:52 PM Thread Starter
cpistorius
dude, its a $500 jeep that i bang up in the mountains on weekends....
post #5 of 13 Old 03-14-2011, 04:11 PM
Jeepican
1976 CJ5
ok so you lift the body 3" to allow for 33" tires.... all you have gained in clearance is about 2" difference from a 31" tire vs 33".....
-Barney Fife-
Jeepican is offline
post #6 of 13 Old 03-14-2011, 04:15 PM Thread Starter
cpistorius
yep and it looks a heck of a lot cooler too!
post #7 of 13 Old 03-14-2011, 04:16 PM
Coiz
1979 CJ7
I would lightly rub the rear tires with a 4" Skyjacker Soft Ride and 33's. Adding a 2" body lift will clear 33's but they will hit the rear fenders at some point. I'd think the 32x11.5 would be a good choice for you. Either that or cut the rear fender wells.
Mike
Coiz is offline
post #8 of 13 Old 03-14-2011, 04:19 PM
JoonHoss
2011 JK Wrangler
actually, you gain about 1" of additional (ground/drivetrain)clearance.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #9 of 13 Old 03-14-2011, 04:23 PM
Jeepican
1976 CJ5
Hoss
Either way... there is no benefit in doing this. And sorry no it does not make it look cooler.... large body lifts do not look good... the majority will agree. Not to mention everything you will have to lengthen to make it work and the stability / safety of those longs mounts. I say go 1" body lift and .5" shackle and you could proly go with some 32" just my
-Barney Fife-
Jeepican is offline
post #10 of 13 Old 03-14-2011, 04:25 PM
robdoggydog1
1970 CJ5
the clearance for drive train is nice by adding the bigger tires, if you havent got the 3" body lift already i would go with max. 2" body lift and do a shakle lift for the rest that way you get your bigger tires and more gas tank clearance etc.... i live in the mountains and know that both body and suspension lift are important in the back woods..
robdoggydog1 is offline
post #11 of 13 Old 03-14-2011, 04:26 PM Thread Starter
cpistorius
never done this, what does everyone else think?
post #12 of 13 Old 03-14-2011, 04:53 PM
Coiz
1979 CJ7
The consensus around the JF seems to be 1" BL max and .5" shackle lift max. If you want more than that you should get a suspension lift or any combination of the above.
IMO, anything more than a 1" BL looks terrible and adds a lot of stress on the body and bolts. Anything longer than .5" shackles messes with steering geometry which requires more work to alleviate correctly.
FWIW, I have all three, a 4" SJ Softride, 1" BL and 3/8" lift shackles. I only had the suspension lift with the 33's and would lightly rub with max flex. I added the BL, shackles and cut the fender wells to make sure I woud clear 35's.
Mike
Coiz is offline
post #13 of 13 Old 03-14-2011, 06:07 PM
4lowherewego
1979 CJ7
I would try find someone parting out some lift springs. Put the 3inch body lift on and look for springs.
79CJ7 360 .030 over, mc2100, T150, Dana20, Trak-Lock'd AMC20, 4" Skyjacker springs, 33" Boggers on aluminum American Racing rims.
4lowherewego is offline
cj7 , lift advice
SOA lift and tire size? davefreeman Jeep CJ Forum 21 03-27-2010 12:52 PM
Need Advice, lift, no lift, tire size, wheel spacers??? darwood112 Jeep CJ Forum 3 03-25-2009 12:55 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
How much lift for a particular tire size? supraman1990 Jeep CJ Forum 6 04-03-2007 09:28 PM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 09:38 PM
