Max tire size - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Max tire size
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-22-2009, 07:32 AM   #1
coastie11
1983 CJ7
Max tire size
What is the largest tire I can put on my CJ7 with just a 1" shackle lift. My son tells me he had 33/12.5/15 on the 86 CJ7 with a shackle lift and had no rubbing. Only off roading would be the beach/dunes. Thanks. Coastie.
coastie11 is offline   Reply With Quote
Unread 06-22-2009, 08:18 AM   #2
JimNut
You might be able to physically fit the 33's under the jeep but I would expect some rubbing. Especially if you start bouncing out in the dunes. Do you already have the shackle lift or is it something you are thinking about doing?
JimNut is offline   Reply With Quote
Unread 06-22-2009, 08:56 AM   #3
coastie11
1983 CJ7
max tire size
I have two inch shackles but have not installed them yet. I read that should give me 1" of lift. Just got 15X10 wagon wheels yesterday so tire are next.
Unread 06-22-2009, 09:02 AM   #4
JoonHoss
2011 JK Wrangler
that really depends on the condiotion of your (stock?) springs
if they are severely settled, a small (~1") shackle lift may not even bring you back to stock height.
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Unread 06-22-2009, 12:00 PM   #5
1984CJ
If you are not running hard off road you might get by with a one inch lift and 33's.
Stock CJ shackles are 3" center to center. 1" lift shackles will be 5" center to center.
Some castor angle problems would not surprise me with a 1" shackle lift.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline   Reply With Quote
Unread 06-22-2009, 01:11 PM   #6
CJ Chet
From my experience, they will DEFINITELY rub!
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 AEV RUBICON.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
