Max tire size - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Max tire size
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 02-07-2009, 06:42 PM   #1
479AZ
1978 CJ7
Max tire size
My 78 CJ7 has a 2-1/2 suspension lift that the PO installed. I have 31" tires now that are getting pretty worn. I would like to go up to 32" but some of the charts I've been looking at say that 31 is the max tire for a 2-1/2 lift. I did a brief search on lifts but didn't find anything. Anyone have an accurate chart on tire size/lift size?
479AZ is offline   Reply With Quote
Unread 02-07-2009, 07:25 PM   #2
Rob55
4wd.com has some charts to use, but from an experience perspective it will depend on your lift (manufacturer). I ran a 2 1/2" RE lift with a 1" body lift and cleared 33" tires. If it were me I'd buy the 32" and keep a 1" body lift as an option if you find clearance problems.Hope that helps.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline   Reply With Quote
Unread 02-07-2009, 07:44 PM   #3
sgtbookie
1982 CJ5
JP Magazine did a tire fit guide a few months back.
http://www.jpmagazine.com/techarticl...ide/index.html
- 1982 CJ5 -
AMC 258 TeamRushed, MC2100, T-176, Dana 300, Goodyear AT 31's, AMC AM Radio, SuperTop, Tuffy Stereo Console , Black Diamond AT Shocks , CJ Draw Bar, Herculiner
sgtbookie is offline   Reply With Quote
Unread 02-07-2009, 07:48 PM   #4
offroadutopia
throw a set of tube fenders cut back at cab side and rock 35s. clearance the back corners of bottom rears. next worry axles. stay in 31-33 with stock axles!
offroadutopia is offline   Reply With Quote
Unread 02-07-2009, 08:15 PM   #5
mcurcio1989
1976 CJ7
Don't know if this will help you but my $.02 would be to try and find someone you know who has that size tire to try and throw on there. When I got new tires thats what I did because on a 30+ year old car there is just no chart for everything. One person will tell you one thing and another person will tell you something else. For me the problem wasn't fenders it was the front tires being close to the leaves in a tight turn.
Disregard everything i say
I have a dana 30 front axle and amc 20 rear if anyone is looking. Both are 3.54, drums, narrowtrack.
mcurcio1989 is offline   Reply With Quote
Unread 02-07-2009, 08:27 PM   #6
duffer
1955 CJ3B
Borrowing a tire and wheel will only tell you what the clearence will be for that wheel. Measure the backspacing so you can compare it to what wheel you intend to use!!!
duffer is offline   Reply With Quote
Unread 02-08-2009, 09:31 AM   #7
Performance
1979 CJ5
My '79 CJ5 has a 2 1/2" Rancho lift. I am running 33 x 12.50 Mickey Thompsons with no problems. Never had them to rub. 4wd.com says 32" tires are max on a 2 1/2" lift. They may rub on some hard core wheeling, but there is plenty of room for 33s. I actually ran 32s on it stock. Bad thing with a Jeep, just because they fit good on mine, doesn't mean they will fit good on another Jeep.
1979 Jeep CJ5 Silver Anniversary - 305ci Chevy With TH350 Trans, 268H Comp cam, 570 Street Avenger Holley, Hedman headers, Super 40 Flowmasters, 2 1/2 Rancho Lift, 15x10 Eagle Wheels, 33x12.50 Mickey Thompson Baja MTZ Tires, Custom Full Roll Cage, Line-X Interior, Custom Rock Crawler Bumpers, Bestop Trailmax Seats, Autometer Gauges, Bestop Supertop.
Webpage link: www.freewebs.com/chromed88ss
Performance is offline   Reply With Quote
Unread 02-08-2009, 10:24 AM   #8
trailridin4x4x4
1981 CJ7
i'm running a 2.5 skyjacker lift and a 2" bl as well as 2" cut out of the front fenders and tub covered with tj wrangler flares and i'm running 35" wrangler mtr's with no rubbing infact i'm have room for 36's.
81 cj7,4.0 mpi,t5/dana300 twinsticked,35 wrangler mtrs
trailridin4x4x4 is offline   Reply With Quote
Unread 02-08-2009, 07:13 PM   #9
No_Bs
1977 CJ5
2.5" BDS, 1" Body, 3/4" shackle, No flares, scout axles, stock wheels:
35's (no they aren't rubbing, but yes it's close):
33's, stock axles, same lift:
33's fit great, the 35's wouldn't work with the stock axles, just too close to the body.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline   Reply With Quote
Unread 02-08-2009, 08:03 PM   #10
sweetguardian00
1946 CJ2A
my buddy ran a 2.5" Superlift and 34's Narrow Track no Rub
1946 CJ-2A 225/T90/D18
1966 CJ-5 231/T86/D18
1986 CJ-7 258/TF999/D300
1984 C-10 6.2/SM465
Yeah it's a Diesel
sweetguardian00 is offline   Reply With Quote
