Mastercraft seats sitting a little high - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Mastercraft seats sitting a little high
OPTIC ARMOR WINDOWS all sale now !!!!!!!!ExtremeTerrain.com Now Carries Raxiom Off-Road Technology RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 09-05-2013, 07:19 PM   #1
kjonesie
1983 CJ7
I just installed a set of Mastercraft Baja seats and noticed they sit higher than my factory seats. Were my factory seats that worn out or is that just how they are made? They are comfortable but just different.
kjonesie is offline   Reply With Quote
Unread 09-05-2013, 07:51 PM   #2
Kstein
Junior Member
They sit higher than stock. I removed the sliding mechanism from the riser to lower them about a half inch. Not ideal.
Kstein is offline   Reply With Quote
Unread 09-05-2013, 08:02 PM   #3
Tigerjeep79
Tigerjeep79's Avatar
1979 CJ7
Yep. I took out the slider, and the seat bolts right up to the factory brackets. It will be positioned as if the slider were in the rearmost position, but lower. I'm 6'-2" and just about had to duck to see out the windshield. Without the slider it's just about perfect.
Tigerjeep79 is offline   Reply With Quote
Unread 09-05-2013, 08:48 PM   #4
kjonesie
1983 CJ7
Yeah I took my sliders off too and its not bad. Thanks for the replies.
Unread 09-05-2013, 09:48 PM   #5
Fins
1980 CJ7
I too removed the seat sliders. Much better fit for me.
Fins is offline   Reply With Quote
Unread 09-06-2013, 08:52 PM   #6
kjonesie
1983 CJ7
So whats the distance y'all have from the top of the seat bottom to where it mounts to the floor board? After driving around in it some today, I still think they are sitting too high.
Unread 09-06-2013, 10:39 PM   #7
Fins
1980 CJ7
I never actually measured the old seat height compared to the new with/without the slider. It still feels high, but it's comfortable for me.
Unread 09-07-2013, 10:03 PM   #8
twinstickd20
Cause 2 is better than 1
twinstickd20's Avatar
1979 CJ7
My seats set too high on the factory mounts, I used a set of corbeau brackets and was able to keep the slider and it leveled them out because they were tilted back on the factory brackets and I could barely get my leg between the seat and steering wheel.
My Build Threadhttp://www.jeepforum.com/forum/f22/p...seven-1090289/
twinstickd20 is online now   Reply With Quote
Unread 09-08-2013, 05:06 AM   #9
keith460
Jeep. There's Only One
keith460's Avatar
This seems to be a problem with the aftermarket seats. At 6'-1", I must also duck my head down in order to see traffic lights because my Rampage seats sit up higher than the OEM ones. I don't know if it is the new seats or seat riser that are causing the problem but I have been thinking of removing the seat sliders on both sides to bring them back down. Removing the sliders will lower my seats 1-1/2".
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 09-08-2013, 09:09 AM   #10
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
So the Corbeau brackets are lower than factory? Or just tilted?
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline   Reply With Quote
Unread 09-08-2013, 11:16 AM   #11
twinstickd20
1979 CJ7
Lower and tilted a little to allow the aftermarket seats to sit like they should
Unread 09-08-2013, 09:10 PM   #12
kjonesie
1983 CJ7
Do the brackets alow for the seats to tilt forward?
Unread 09-08-2013, 09:45 PM   #13
twinstickd20
1979 CJ7
No that's the only downfall but is ok for since I don't have a back seat
Unread 03-19-2014, 10:44 PM   #14
zippoguy
Junior Member
I just installed mine, I'm only 5'8", my problem is not hitting the top, although almost. I can barely reach the pedal lol I have to sit super close. Man, I feel like a midget!
zippoguy is offline   Reply With Quote
Unread 03-23-2014, 09:36 AM   #15
84jeepjohn
I am in the same boat as everyone lese, I'm 6'2" and I'm fine with the driver side and no slider (it's a bit high, but after 3 years I'm used to it.... anyone shorter ((my son)) has a hard time driving though )
For the passenger side I got a YJ mount (seat bracket) and it's about 1-2 inches lower than a CJ's I have a slider on that side and it's good.
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline   Reply With Quote
