Master Cylinder Question - Should this be leaking? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Master Cylinder Question - Should this be leaking?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueOfficial Chassis Saver Rust Preventive Truck & Auto Un
Unread 03-30-2014, 07:34 AM   #1
RadioRadio
1980 CJ5
Hey Gang....I'm replacing my master cylinder and my new one (a NEW, (not reman) Dorman unit) starting leaking right here at the main piston pedal diaphragm while I was bench bleeding.
Is it OK to leak here? It come with a rubber boot to close over it, not currently installed.
It just seems like this should be sealed...I dunno.
1980 Jeep CJ5 MANUAL brakes.
Lemme know your thoughts, I appreciate the help!
You can see the little puddle at the bottom of the cylinder...
RadioRadio | 1980 CJ-5 - Classic Hardtop/Doors, Bestop Tigertop/Bikini, All Steel, 50's Jahco Winch, Tailgate, Vintage CB, Stock Motorola AM/FM
RadioRadio is offline   Reply With Quote
Unread 03-30-2014, 07:40 AM   #2
Ken4444
Corripe Cervisiam
Ken4444's Avatar
That should not be leaking.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote
Unread 03-30-2014, 07:51 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Most definitely not! I went through a bunch of remanned ones that all leaked there when bench bleeding. Ended up having to change brands.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 03-30-2014, 08:06 AM   #4
WindKnot
WindKnot's Avatar
1977 CJ7
Nope! That's a reason to replace or rebuild the master cylinder.
bumped to the top
Be kind. If for no other reason, it will confuse the daylights out of people and make them wonder what you're up to. And ALWAYS drink upstream of the herd!
WindKnot is offline   Reply With Quote
Unread 03-30-2014, 08:10 AM   #5
RadioRadio
1980 CJ5
Facepalm...thanks guys...kinda figured.
Is there any other MC option other than Cardone or Dorman?????
I thought I was safe going with a new, not reman'd...but apparently not.
Not a big fan of Cardone, but I'm willing to give them a shot, if those are the only two MC suppliers out there.
Unread 03-30-2014, 08:17 AM   #6
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This post is a good lesson to remind folks to bench bleed their master cylinder. Doing that lets you check if it's leaking or not, before it goes in the Jeep.
