master cylinder install - JeepForum.com
post #1 of 17 Old 03-28-2011, 07:09 PM Thread Starter
twistedaase
1983 CJ7
Does anyone have a good write up on brake master cylinder install on a 1983 cj7? I thought it was going to be bolt off bolt on but looks like there might have to be a rod removed from old to new. Thanks.
twistedaase is offline
post #2 of 17 Old 03-28-2011, 07:39 PM
Skerr
Where did you get it? Is it a factory replacement? Power or manual? How many bolts at the firewall? The rod you are talking about, I'm thinking, is the rod that connects to your brake pedal? It should have come with it. Did you bench-bleed it first?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3 of 17 Old 03-28-2011, 07:40 PM
VACJ7
VACJ7's Avatar
Been a few years but if I remember correctly your first assessment is correct. Unbolt, remove, bench bleed new one, bolt on. In fact I know I did not have to swap out a rod, at least with my power brakes.
VACJ7 is offline
post #4 of 17 Old 03-28-2011, 08:29 PM Thread Starter
twistedaase
1983 CJ7
yeah the remanufactured one came with no rod and the only rod i see is the one going in the booster. So it looks like it bolts right on . But can i bench bleed it bolted on the booster.
post #5 of 17 Old 03-28-2011, 08:45 PM
VACJ7
VACJ7's Avatar
I've only done it on a bench per the factory service manual. Usually the remans come with a bench bleeding kit. If not, they are cheap at any parts store.
VACJ7 is offline
post #6 of 17 Old 03-28-2011, 08:46 PM
robdoggydog1
1970 CJ5
thats funny i always thought about this.... so finally i did it on my last mc swap. turns out its a good way to bench bleed unless..... you get a bad mc to start with, ask me how i know , lol. i think the benifit is if you do get a bad one at least its not installed. Maybe other reasons but this is the most reasonable difference i see.
robdoggydog1 is offline
post #7 of 17 Old 03-28-2011, 08:56 PM Thread Starter
twistedaase
1983 CJ7
well i dont have a vise to hold the mc so i guess i will have to do it mounted on the booster. in the pic it shows the tubes going back in the mc is it ok to just use a bottle with fluid.
post #8 of 17 Old 03-28-2011, 09:21 PM
Skerr
It's worth the effort/time to get the bleeder kit. The tubes bend back into each reservoir eliminating any chance of inadvertently pumping air back into the system. Otherwise, you'd have to connect your brake lines and you'd end up pumping the trapped air in the MC right into your lines. You could bleed it mounted to the firewall using the brake pedal. Bleeding Jeep brakes is pain enough without pumping extra air into the system... IMO!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #9 of 17 Old 03-28-2011, 09:26 PM Thread Starter
twistedaase
1983 CJ7
It came with 2 plastic bleeder screws and 2 clear hoses that i attached and put the tubes into bottle of fluid i tried pumping the brakes and no fluid is coming out of the tubes , i do notice air bubble very very slowy coming out of the first hole in the reservoir closed to the booster.
post #10 of 17 Old 03-28-2011, 09:30 PM
Skerr
Should be a plastic clip that fastens over the divider between the two reservoirs. The tubes attach to the clip. It holds the tubes in each reservoir. The idea is to keep the fluid level over the ends of the tubes. Each time you make a stroke it moves the fluid, in or out. It would work in the bottle but it will make it harder to see the bubbles, again, IMO. You can see it easily when the tubes are in plain sight.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #11 of 17 Old 03-28-2011, 09:33 PM
Skerr
Check out the first page of this thread.... lots of pics.
http://www.jeepforum.com/forum/f8/sc...5-cj7-1147913/
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 17 Old 03-28-2011, 09:50 PM Thread Starter
twistedaase
1983 CJ7
the smaller reservoir is bleeding fine but the larger one seems to have an air lock and the brake lights are stuck on
post #13 of 17 Old 03-29-2011, 06:44 AM
jessec
1978 CJ5
When you put in on the boster did it push
the piston in? if it did no fluid will inter the
first port. you may have the wrong MC for the
boster you have.
jessec is offline
post #14 of 17 Old 03-29-2011, 08:17 AM
Mike Romain
That is because you didn't bench bleed it.
It has to sit perfectly level to get the air out or you just pump air down the line and mess up the combo valve, you are nowhere close to level on the booster. Even a set of steps will work usually, it gives something to push against and they are usually level.
If they are the kind that need full throws to bench bleed, the brake pedal also won't do that when it is installed, you need a screwdriver or rod for that.
You also have now tripped the combination valve from the sounds of it and may have to have someone pump it up hard, hold the pedal and then crack open a front bleeder screw to switch the combo valve back to center. It thinks there is a leak there and has shut down the circuit.
Mike
Mike Romain is offline
post #15 of 17 Old 03-29-2011, 11:46 AM
Skerr
Thank, Mike, for the correction. I will be careful not to give out bad advise!!
Kerrdog
Go Fish! <*////><
Skerr is offline
master cylinder help raperfam Jeep CJ Forum 8 03-12-2011 05:44 PM
Having problems after new master cylinder install, please help. g_man500a Jeep CJ Forum 5 07-25-2009 12:47 AM
master cylinder gone bad? gotCLAY Jeep CJ Forum 6 12-20-2008 08:20 AM
master cylinder? brettsipperley Jeep CJ Forum 4 10-31-2008 10:13 AM
CJ 5 Master Cylinder....WTB billyroy Jeep CJ Forum 2 05-25-2008 03:27 PM
