master cylinder gasket for 77 cj5??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > master cylinder gasket for 77 cj5???
Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!
Unread 03-30-2014, 08:23 PM   #1
tomcat77
1977 CJ5
Pulled of the master cylinder cover the other day and it cracked the edge of the rubber gasket springing a leak when I drive it. Been to oriellys, autozone and advance with no luck finding the gasket. Quadratec doesn't even list it. Can this be purchased anywhere or do I have to buy a complete master cylinder to get it? Thanks
tomcat77 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 05:56 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Time for a visit to the local auto wreckers. I would take the cover with me. I think it matches some GM ones, but could be mistaken. It was a while back when I had that problem.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 08:30 AM   #3
WindKnot
WindKnot's Avatar
1977 CJ7
If you're talking about the gasket for the cover, I've seen them in the "Help" section at my Autozone. "Help" is a name brand and the section has window cranks, door handles, small plastic parts that commonly break, doodads like that.
I'd bring the cover along and visually match the part.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is online now   Reply With Quote Quick reply to this message
Unread 03-31-2014, 08:41 AM   #4
tomcat77
1977 CJ5
Yes the rubber gasket. I have looked in help section at o riellys autozone and advance. May have to go to another town maybe they carry different stuff? ?
Unread 03-31-2014, 09:05 AM   #5
Mike Romain
If a local place carries the help brand, they should be able to order you one. Our local places will do that.
Mike
Unread 03-31-2014, 11:12 AM   #6
WindKnot
WindKnot's Avatar
1977 CJ7
Actually, I just checked and I have a used spare you can have for the asking. It's for a cylinder for manual brakes, but I suspect it will fit a power brake M/C as well.
So many here have been very kind to me during my rebuild. If I can help someone else it would make ME feel good! PM me if you'd like it.
Unread 03-31-2014, 12:12 PM   #7
tomcat77
1977 CJ5
Pm sent
Unread 03-31-2014, 05:07 PM   #8
WindKnot
WindKnot's Avatar
1977 CJ7
On its way.
