Master cylinder for disc brakes? - JeepForum.com
post #1 of 1 Old 12-27-2010, 05:56 AM Thread Starter
Avon_JeepMan
1977 CJ7
I rebuilt my 1977 CJ7 using reverse-cut Dana 44 axles from a Ford in both the front and rear of the Jeep. The front uses Chevy disc brake calipers, and the rear uses Ford Motor sport disc brake calipers which I purchased from Parts Mike. I like the set up and think it turned out really well. However, the stock 1977 CJ7 master cylinder arrangement does not seem to be providing enough fluid pressure (or volume?).
Because I live in in rural central Minnesota and am not in my mid twenties anymore, I do not drive the Jeep in the winter. So I would like to start on the brakes project now so that I am done before spring.
I would like to start by figuring out what I need to drop a single line down to the front axle and Tee it to both calipers similar to a Dodge set-up.
What size of steal brake line should I use from the master cylinder to the point where is drops down to the front axle?
What size of line should I use from the Tee on the axle to each front caliper?
Is there a bracket that I need to attach the end of the steal brake line and support the rubber hoses on the ends of the axles?
What size of brake line should I run to the back of the vehicle?
Since money is somewhat tight right now, would I gain anything by purchasing a booster and using my existing 77 CJ7 master? I read that the 1977-78 CJ7's used a 1-1/16" cylinder. Would I see an improvement by adding the booster and using my existing (new) stock CJ7 master cylinder or would I be wasting my time?
What is the difference between the 1977 CJ7 master cylinder and the Corvette master cylinder the I will likely be buying in the future?
Does someone have a diagram of your set up?
Avon_JeepMan is offline
Master Cylinder... W/Disc Conversion Rupie25 Jeep CJ Forum 21 03-21-2011 10:09 AM
Brake problem- Master cylinder or brakes? jatepper Jeep CJ Forum 5 08-17-2010 12:13 AM
master cylinder? AdrianW1 Jeep CJ Forum 5 07-22-2010 07:58 PM
Master Cylinder Upgrade - 1985 CJ Manual Brakes Swampdog Jeep CJ Forum 0 03-10-2009 06:47 PM
master cylinder - help 82Renegade Jeep CJ Forum 6 09-27-2007 11:28 AM
