manuel steering to power steering - JeepForum.com
post #1 of 11 Old 07-21-2014, 03:30 PM Thread Starter
bgi3
1983 CJ7
i have manuel steering right now but i have everything but the high pressure hose to do power steering. it is an O-ring power steering box going on my cj with a 99 4.0L. im using the factory pump thats on the 4.0L. what, where, or how am i uppose to go about the hose.
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #2 of 11 Old 07-21-2014, 03:41 PM
dirtdudeaz
1983 CJ7
Was the manuel power steering part of the Mexico Especial package?
Napa, jeep4x4center, quadratec, oreilly, gatozone, etc.... Just pick which one you like best or which one has the best price. Pick a jeep from 1999 with a 4.0L and tell them you need the pressure hose and return hose. I looked at XJ (cherokee) when I searched for PS hoses for 99 4.0... but I am sure others are similar.
Another option is to find a Parker Store. Normally they will do build-to-order custom lines while you stand there, they and carry pretty much any kind of hydraulic part you can think of.
dirtdudeaz is offline
post #3 of 11 Old 07-21-2014, 08:36 PM
tdagner
1980 CJ5
Advance auto parts. Use a coupon code. all you have to do is google Advance auto parts coupon codes. you can usually save 30%. It has saved me hundreds over the past few years.
tdagner is offline
post #4 of 11 Old 07-21-2014, 10:23 PM
Deeznutz73
1973 CJ5
Napa can make you a custom length hose with fittings for about $50 for the pressure line. Just call the and ask if they do it or one of the other shops do. The "truck" shop is the one you're looking for, at least it is here in SD.
The return line can just be a normal fuel hose with a hose clamp, so long as you have the fittings. If not, hit up a junkyard.
This shouldn't be too hard...........
Deeznutz73 is offline
post #5 of 11 Old 07-22-2014, 12:00 PM
carnuck
1984 J-Series Truck
Use trans fluid hose, not fuel line.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #6 of 11 Old 07-27-2014, 06:59 AM Thread Starter
bgi3
1983 CJ7
thanks ill try to find somewhere that can make me a hose.
bgi3 is offline
post #7 of 11 Old 07-28-2014, 12:57 PM
jp360cj
1977 CJ7
The hose for an 80+ CJ with a 6 cylinder should work just fine.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 11 Old 07-28-2014, 01:55 PM Thread Starter
bgi3
1983 CJ7
The hoses I've found are to short or have a bent hard section in them
bgi3 is offline
post #9 of 11 Old 07-28-2014, 05:03 PM
Spieg8
1984 CJ8
What does the 99 4.0 come out of? Where does the steering pump sit on the motor? If you don't know for sure where the motor came from, some pictures of the motor and pump mount might help.
Spieg8 is offline
post #10 of 11 Old 07-29-2014, 04:00 PM Thread Starter
bgi3
1983 CJ7
the motor came out of a 99 xj. the pump sit in about the same spot but the perssure fitting is directly on top on the pump, behind the pully and the return fitting is on the back side. the return line isnt a problem. the factory cj pressure line isnt long enough and the xj line has a hell of a bend in it.
bgi3 is offline
post #11 of 11 Old 07-29-2014, 04:16 PM
dirtdudeaz
1983 CJ7
Parker Store
HYDRADYNE LLC
1635 ASHEVILLE HWY
SPARTANBURG SC 29303
UNITED STATES
Telephone - (864) 585-7412
3.2 miles
