which manual trans for amc 360 + dana 300 - JeepForum.com
post #1 of 14 Old 07-15-2009, 09:31 AM Thread Starter
mike06X
ditching my torqueflite 727 for a manual - whats my best option, with cost a consideration..my plan was a sm465 with some adapters from novak..will a jeep T15 bolt up/no adapters? are there any jeep/amc manual transmissions strong enough/worthy that would mate with a amc360 & dana 300?
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline
post #2 of 14 Old 07-15-2009, 09:37 AM
kickingprop
Depending on how hard you plan to wheel it, a T-176 would be a good transmission to consider.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #3 of 14 Old 07-15-2009, 09:38 AM
lgreve
1977 CJ7
or a T-18 with the Granny first gear would be a good choice if you planed on wheeling it very hard.
Restoration = lots of $ & time thrown at the jeep. I know we all know this but it helps in the process to keep things in perspective.
____________________
CHRISTIAN JEEPER #230
lgreve is offline
post #4 of 14 Old 07-15-2009, 10:15 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The T176/177 will bolt up with factory adapters. It is a medium duty "true 4 speed" with very nice road manners and pretty good strength. I run a T176 behind my 360 and used a 4:1 kit in the D300 to get a little better gearing offroad (with a 33" tire and 3.73 axle gears). It's a nice street/trail setup.
BESRK is offline
post #5 of 14 Old 07-15-2009, 10:45 AM
BillyPilgrim
1979 CJ7
t176 and t18 are good choices. The 18 is super strong but basically gives you a 3 speed for normal driving due to the low first gear. Great for wheeling though. I drive my 7 with a 304 on street to run into town and what not and I am looking for something like the ax15 or if I had the money the NV4500 to get the over drive, with my gearing I am turning way higher RPM's than I need to be for the v8 on the highway with the direct drive final.
BillyPilgrim is offline
post #6 of 14 Old 07-15-2009, 10:52 AM
LGreevesCJ7
1977 CJ7
If you like the sm456 then the T18 would be a good choice.
LGreevesCJ7 is offline
post #7 of 14 Old 07-15-2009, 11:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The T-18 would need an adapter to the Dane 300 though. thats like anouther $500-$600.
John Strenk is offline
post #8 of 14 Old 07-15-2009, 02:01 PM
asf06
T-18 for sure. if not, im also a fan of the SM465
1993 YJ, too broke to swap the tranny and my 60s
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
PIKE Jeepers #1
Jeep Smokeless #4
asf06 is offline
post #9 of 14 Old 07-15-2009, 04:08 PM
rustymudder
1982 CJ7
I'm in the middle of a t18 swap in my cj. The t-18 is gonna drive like the truck it came out of, an 84 f250, but that's what I expect so its good. I also wanted the granny low and since my axles are 3.31s I never used 5th gear anyway. I also like the fact that I could stick a 428 cobra jet in front of it and not worry about the tranny
rustymudder is offline
post #10 of 14 Old 09-06-2009, 11:28 AM
SKT
Would an AMC 360 with a Dana 300 and a SM465 be a compatible and stout setup. I plan to run 44's front and rear, and the vehicle will be street, with some mild wheeling. Just want to make sure I have a stout drivetrain, that I don't want to worry about breaking stuff if I do get into some harder stuff.
Thanks
SKT is offline
post #11 of 14 Old 09-06-2009, 07:51 PM
my84cj7
T-176/T-177 either one will bolt up to your D300
my84cj7 is offline
post #12 of 14 Old 09-07-2009, 06:16 AM
84cj
T-176 is a lot more street friendly. SM465/T18 are truck transmissions with 3 street gears. Lacking in the gear department for highway, you gain a very handy low gear and a bullet proof trans. The 176 would be the more economical way to go as it was originally bolted to AMC engines and the D300.
Jeeps are built, not bought.
5.7 TBI, sm465, d-300, d30, m20.
84cj is offline
post #13 of 14 Old 09-07-2009, 09:18 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
While I like the SM series, when using an AMC engine and bellhousing, the swap is easier if you go with existing transmissions that will fit. These include the 150 three speed, 176 four speed and the Ford or Jeep version of the T18.
The 150 and 176 are Tremac (Ford) medium duty transmissions that were offered stock inn the 76 and later platforms. They have given years of good service behind Ford and AMC V8 engines.
The T18/19 gives you two choices of first. The 6.3 granny low transmission is basically a three speed with a compound low for offroading. This is a great transmission if you are having problems getting slow enough through technical sections. The Jeep/Ford T18/19 also comes with a 4.0 first gear. This is a much nicer onroad transmission (If you could use that term with any T18) and gives you true four speed gearing. The great thing about these transmissions is they are a virtual bolt up to the existing 76 and later bellhousing. Do a search on the Novak sight. They have a huge knowledge base on these boxes.
jeepdaddy2000 is offline
post #14 of 14 Old 09-07-2009, 10:57 AM
JeepnBlake
i've had both the t-18 (4.0) and the t-176, the 176 is by far the way to go if you're going to use it on the street much. Around here you can find t-176 d300 combos a lot easier than you can find the d20 or t-150 or t-18.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
Vacuum routing for 76 CJ& with 304 and a Manual Trans Woolys_CJ7 Jeep CJ Forum 1 01-23-2010 05:16 AM
auto vs manual trans in a scrambler cscotted Jeep CJ Forum 23 02-27-2009 12:39 PM
Manual trans Redmanchew Jeep CJ Forum 0 12-18-2006 06:12 AM
Auto or Manual Trans? wyocj7 Jeep CJ Forum 7 12-04-2006 09:24 AM
Swap from Auto to manual trans BIGJMCCONNELL Jeep CJ Forum 5 02-11-2003 01:44 PM
