Manual Steering rebuild? - JeepForum.com
post #1 of 10 Old 10-10-2003, 07:49 AM Thread Starter
Aphelion79
Aphelion79's Avatar
I see one for power steering, and I need to get some suggestions on what to do about this problem.
I've got at least 2 to 4 inches of play in my steering... the pitman arm drops down and "clunks" (quite loud if im not moving and the wheels are on the ground) before it turns... what exactly could be worn out in a 21 year old steering box that I could get from a parts store to rebuild?
I have no idea whats in the box or anything, all I know is that the play isnt from tie rod ends or the steering shaft... its got to be the steering box...
Aphelion79 is offline
post #2 of 10 Old 10-10-2003, 01:28 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Help!
BUMP* I'd like to be able to go over 45 without swerving all over the road like a mad man, lol... anyone?!
post #3 of 10 Old 10-10-2003, 01:54 PM
cjryder
4WD Hardware has a replacement box. That's the route I am taking
75 cj5 , 51 m38
"the wife asks 'why 2 jeeps?', I tell her that's all I could find so far"
cjryder is offline
post #4 of 10 Old 10-10-2003, 06:06 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Yeah i know, a few places do... just trying to avoid paying 100+ dollars if theres some sort of rebuild kit that replaces common worn out parts?
post #5 of 10 Old 10-12-2003, 05:02 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Aparently not, just ordered one from Auto Zone...
post #6 of 10 Old 10-12-2003, 06:11 PM
DustinsCJ7
DustinsCJ7's Avatar
How much was one from autozone??
Thanks
P.O.S Jeep club member #2
84 CJ7 nuttered up, TFI'ed, MC2100 conversion, 2" spring lift, 31" BFG MT's
79 LUV 4x4
Live like there's no tomorrow
DustinsCJ7 is offline
post #7 of 10 Old 10-12-2003, 07:35 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Thanks
Approx. 129.99 plus like 45.00 core charge... so not bad!
post #8 of 10 Old 10-12-2003, 10:47 PM
DustinsCJ7
DustinsCJ7's Avatar
sweet! thanks for letting me know
79 LUV 4x4
post #9 of 10 Old 10-13-2003, 08:03 AM Thread Starter
Aphelion79
Aphelion79's Avatar
No problem! I should get it around wednesday or so... so I'll let you know if theres anything wrong with it, etc.
post #10 of 10 Old 10-13-2003, 10:48 AM
twmattox
Quadratech has a rebuild kit for the Manual (just found out) for around $80.
Sounds like the worm bearing preload is off on your unit. You may get lucky and just need to adjust yours.
Always set worm bearing preload prior to adjusting the pitman arm...let me know in a PM if you need instructions (I should be able to get you a PDF of the Tech Manual)...
twmattox is offline
DANA 300 Rebuild Manual / Specs RetiredSERE Jeep CJ Forum 9 09-23-2009 07:06 AM
CJ-7 Rebuild: Automatic vs Manual transmission portocar Jeep CJ Forum 11 06-10-2007 08:52 PM
Manual steering gearbox rebuild? wwhitby Jeep CJ Forum 5 11-11-2005 03:11 AM
Best Rebuild Manual longlimb Jeep CJ Forum 6 07-30-2005 12:02 PM
T-5 rebuild manual mrk204 Jeep CJ Forum 1 03-07-2005 08:16 AM
