Quantcast manual hubs, need help, lots of it - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > manual hubs, need help, lots of it
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 12-19-2005, 08:37 PM   #16
Geer_hed
Funny, I hesitated to say anything, because I hate messing with hubs, but I guess I should've
Source
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Old 12-19-2005, 08:38 PM   #17
Blackjackbender
only one side has the problem. there is still play in the axle shaft. gonna take the spindles off and pull the shafts and replace the bearings in there. heres some pictures.
seems like theres more problems think im gonna remove the spindle and remove the shafts and inspect in there. mineaswell when i have everything out, hubs and bearings seem fine suprisinly
2000 TJ, flipped 300. HP60 w/3 link. 14 bolt leaf sprung. 107" wheelbase
Blackjackbender is offline   Reply With Quote
Old 12-19-2005, 10:01 PM   #18
jeepdaddy2000
1971 CJ5
Try to rotate the spud shafts to check the U joints. Don't pull the shafts if you don't have to. That will keep you from running the risk of getting crud in the inner axle seals, causing them to leak.
jeepdaddy2000 is offline   Reply With Quote
Old 12-20-2005, 12:39 AM   #19
Iceman_RNR
there is some play in the shafts, otherwise they would bind up in turns
Regreasing those hubs would't hurt and now would be the time to replace the seals and regrease the bearings
'84 CJ7, '96 CTD, '00 TJ
Originally Posted by NotURMailman View Post
I did that so that some infantile ego-maniac like you wouldn't go all into attack retard internet thug mode like you just did.
Anyway.... I'm out!
Iceman_RNR is offline   Reply With Quote
Old 12-20-2005, 03:38 PM   #20
Blackjackbender
only thing that has me concerened is my detroit locker hasnt been working that well if any at all, im thinking that somehow the splines are stripped?
thanks
Ty
Old 12-20-2005, 11:28 PM   #21
Iceman_RNR
thanks
Ty
just pull the shafts (or the complete hub assembly) to check on that. Twisted splines will still engage the locker.
Just open up all the crap to see what's going on
Anyway.... I'm out!
Old 12-21-2005, 09:45 PM   #22
Blackjackbender
the new bearings fixed everything, will find out about the axle some other time.
thanks for the help.
Glock Forum
