Manual brake to power brake conversion questions - JeepForum.com
post #1 of 8 Old 06-27-2012, 10:02 AM Thread Starter
Alex77cj7
1977 CJ7
I'm wanting to install power brakes on my 77 cj7 but I am not sure what all I'd need to buy and change to install it. Would i be able to just buy the brake booster at a parts store and just install that with my stock line an master cylinder or would I have to change all that too? I'm also thinking about swapping my front drums to discs from a jeep of the same year. Would I be able to just go to a parts store and buy calipers and discs and install that? I'm really confused and need help so any little bit would be greatly appreciated!
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
post #2 of 8 Old 06-27-2012, 10:26 AM
Dadamsnv
1977 CJ5
I also have a 77 CJ, but mine's a 5. So far the best manual to power brake conversion I have seen and will be doing in the next few weeks uses a yj master cylinder and booster in place of the CJ master. Apparantly the best year for a donor is 95 for some upgrade reason. Luckily there is a good one in town for me, the guy wants $100 for the full assembly, but i think I can get $80. The only modding necessary to make it fit is you have either lengthen or shorten the booster input linkage a bit.
Use the search bar at the top of the site, that's how I found out about all this. good luck!
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #3 of 8 Old 06-27-2012, 10:40 AM
jpd1899
1978 CJ7
To go with power brakes you may also need a new proportion valve to re-adjust the flow to the brakes. Depending on your donor parts, they may require new lines to/from the valve to cylinder.
A front disc brake conversion, requires a lot more than just calipers pads and cylinder. I don't have much time on my lunchbreak to find you a few articles to point you in the right direction. but here is one
http://www.jeepforum.com/forum/f8/di...-i-use-943611/
In short you need to replace everything from the nuckles out to make it work.
There is alot of info on the forum about this specific topic. If you are having a hard time finding it through the forum search, try using google and included jeepforum (one word) in the search
jpd1899 is offline
post #4 of 8 Old 06-27-2012, 11:27 AM Thread Starter
Alex77cj7
1977 CJ7
Thanks for the help! At least you were able to get me going in the right direction! But if I go to a parts store and get the booster and master cylinder for a 77 with power brakes would it just bolt up?
post #5 of 8 Old 06-27-2012, 11:34 AM Thread Starter
Alex77cj7
1977 CJ7
I'd rather start with brand new parts.
post #6 of 8 Old 06-27-2012, 03:33 PM
oteps
1980 CJ5
There is a bracket between the M/C and the firewall. Your old m/c just bolts right to the firewall. I used a 89 xj booster and m/c but I had to make a braket and a new rod. I dont know anything about the disc brake swap.
oteps is offline
post #7 of 8 Old 06-27-2012, 03:41 PM Thread Starter
Alex77cj7
1977 CJ7
Would I be able to use stock brake lines?
post #8 of 8 Old 06-27-2012, 03:41 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i have a booster and mc that I just took out of mine when i put in hydroboost brakes, they worked great until i threw some 37's on it lol
if you are interested ill sell it to ya cheap.
if not then i cant say enough with VANCO brakes, they are absolutely amazing.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
