manual to automatic - JeepForum.com
post #1 of 4 Old 10-04-2002, 05:41 AM Thread Starter
jeephandyman
Question manual to automatic
I have a 82'cj7 with 258 6 cyl and t5 trans i want to change to an th400 auto trans what parts will i need from donor jeep to make this go smooth? I know i need the following , but is there anything i'm overlooking? i have trans, trans mount, skid plate, auto column, pedal assembly,linkage and brackets. Also i have 33" tires with 373 gears and needless to say it s not i good combo i want to change gears and install lockers what would be my best choice i dont off road much but i love the snow
jeephandyman is offline
post #2 of 4 Old 10-04-2002, 08:46 AM
CSP
Hopefully you have an AMC patteren Turbo 400. A Chevy or any other T400 won't bolt to the AMC block. Adapters can make it possible, but it's unneccesary since AMC T400's are easy to find. CJ's and full size Jeeps which had autos up to 1979 had the T400. If you have the right tranny you're going to need to adapt the tailshaft for the transfer case. The Jeep T400 almost exclusively had the Quadratrac tcase behind it. You definitely don't want to swap your Dana 300 out for the qtrac. Novak can set you up with the right adapter to bolt the 300 up to the 400. www.novak-adapt.com The 400 is quite a bit longer than your T5, so you're probably going to need new driveshafts. Your rear one will be too long and the front will be too short since the transfer case will be closer to the rear axle. Both existing shafts can be retubed or you can buy new ones.
CSP is offline
post #3 of 4 Old 10-04-2002, 10:51 AM Thread Starter
jeephandyman
yes I have a AMC 400 and a 300 transfer case about the drive shafts- will the donor jeep drive shafts work for me?
post #4 of 4 Old 10-04-2002, 11:27 AM
CSP
Maybe, maybe not. The donor Jeep (guessing CJ7 with Qtrac) has a different length transfer case than your 300. The difference may be small enough to reuse them. The only way to find out is to try them once the swap is done. Even if they don't you really have to have everything in place to get an idea what the driveshaft lengths will need to be. You can't guess or estimate it with a tape measure.
CSP is offline
Automatic Column in Manual CJ? Hybrid Jeep Jeep CJ Forum 3 12-04-2009 10:57 PM
cj-7 manual or automatic psbeaman Jeep CJ Forum 17 06-17-2009 02:52 PM
converting automatic choke to manual jagerlager Jeep CJ Forum 3 08-24-2008 09:12 AM
Swap Automatic For Manual Davey4000 Jeep CJ Forum 0 05-13-2006 06:20 AM
Automatic to Manual tranny? TrappG Jeep CJ Forum 6 09-15-2003 11:09 AM
