Quantcast Making Battery/Starter Cables Correctly... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Making Battery/Starter Cables Correctly...
Old 02-10-2009, 03:40 PM   #16
JeepHammer
Running On Empty...
1973 CJ5
LINKS FOR TOOLS & PARTS.
TOOLS.
Cable Lug Hammer Crimper,
Fastenal p/n 0844004, $12.50
http://www.fastenal.com/web/products/detail.ex?sku=0844004
Fastenal p/n 0717149, $54.89
http://www.fastenal.com/web/products/detail.ex?sku=0717149
Cable Lug Compound Crimper,
Fastenal p/n 0715837, $350.48
http://www.fastenal.com/web/products/detail.ex?sku=0715837
Powered Crimping Tool,
Fastenal p/n 0716741, $1,488.84
http://www.fastenal.com/web/products/detail.ex?sku=0716741
Fastenal p/n 0716756, $4,268.08
http://www.fastenal.com/web/products/detail.ex?sku=0716756
Cable Stripping Tool,
Fastenal p/n 0717142, $36.43
http://www.fastenal.com/web/products/detail.ex?sku=0717142
Heat Gun For Heat Shrink,
Fastenal p/n 0713794, $43.94
http://www.fastenal.com/web/products/detail.ex?sku=0713794
Cable Cutters, (Channel Lock)
Fastenal p/n 02558240347, $27.93
http://www.fastenal.com/web/products/detail.ex?sku=02558240347
JeepHammer is offline   Reply With Quote
Old 02-10-2009, 04:04 PM   #17
JeepHammer
Running On Empty...
1973 CJ5
PARTS, Consumables.
Heat Shrink Tubing,
http://www.fastenal.com/web/products.ex?N=999601362&Nty=0
48" lengths (that's 4 Feet for you Heep'ers!)
Fastenal Book,
0.30" ID,
p/n 0705417 Black, $26.80,
p/n 0714600 Red, $18.96
0.40" ID,
p/n 0705418 Black, $27.93,
p/n 0714601 Red, $18.96
0.80" ID,
p/n 0705419 Black, $26.29
p/n 0714602 Red, $18.96
1.10" ID,
p/n 0705420 Black, $30.18
p/n 0714603 Red, $23.15
1.50" ID, p/n 0705421 Black, $40.63 Ea.
2.00" ID, p/n 0705422 Black, $54.22 Ea.
Straight, Crimp Type Battery Terminals.
(there are 90°, Flag Terminals, ect. available other than 'Straight')
Positive, 2/0 Gauge, Straight, $4.74Ea. Fastenal p/n 0715672
Negative, 2/0 Gauge, Straight, $4.74 Ea. Fastenal p/n 0715671
Positive, 1/0 Gauge, Straight, $4.74 Ea. Fastenal p/n 0715670
Negative, 1/0 Gauge, Straight, $4.74 Ea. Fastenal p/n 0715669
Positive, 1 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715668
Negative, 1 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715667
Positive, 2 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715666
Negative, 2 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715665
Positive, 4 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715664
Negative, 4 Gauge, Straight, $4.65 Ea. Fastenal p/n 0715663
For a Cleaner Install, You can also order 90° Termianls, to the LEFT or RIGHT,
LEFT,
RIGHT,
And if you are going to connect the grounds together, I suggest a 'FLAG' connector,
AND,
For those of you doing 'Add Ons' like stereos, Communications Radios, Inverters, Welding From Your Batteries,
I suggest something like this for connections for all that stuff...
Heavy 'Eye' or 'Ring' terminals are pretty hard to find sometimes...
Here are the ones that are heavy enough for ANYTHING you might want to do,
And REMEMBER, these are STACKABLE, you can connect two or three to the same terminal, if the bolt holding them together is long enough!
Plain old tubing 'Ring' or 'Eye' terminals,
Now remember, anyone with copper tubing can make a connector like this at home for cheap!...
BUT,
If you are buying them, the size of the eye hole is an issue! 5/16" (shown) is the most common electrical connector size on your vehicle...
The starter relay, starter, ect. will all accept the 5/16" hole connector shown.
SOLDER!
Sliver Bearing, Rosin Core, intended for ELECTRICAL WORK,
Not that old, cheap plumbing solder!
The best I've used that is commonly available is from Radio Shack, p/n 64-013. You may have to double it up three or four times to make it easy for the big cables, but the fine strand solder is PERFECT for smaller terminals when you are chasing the 'Electrical Bugs' out of your 'Heep'!
http://www.radioshack.com/product/index.jsp?productId=2062717
Old 03-17-2009, 10:05 PM   #18
whittlecj
1980 CJ7
I like this thread, thanks. I tried today to find someone to make some cables for me and not many do this anymore! The local parts stores (even the good ones!) don't do it any more, nor do the NAPA stores in the area. The West Marine told me I could make them at their store but that they could not. I'll go check them out and see what type of stuff they have.
______________________________________
In Process: 2002 4.0L and NV3550 Swap
whittlecj is offline   Reply With Quote
Old 03-17-2009, 10:48 PM   #19
neonistic
1981 CJ7
I vote for Article status, or at least a sticky!
You're going to hate Fridays!
neonistic is offline   Reply With Quote
Old 03-18-2009, 05:16 AM   #20
Exposed
Exposed's Avatar
1981 CJ5
Terminal Hammer Crimper..
Last year I added Solar Panels to my Toy Hauler... I used a bunch of welding lead in the wiring of 4- 6 volts batteries... These hammer crimpers work great if you have a normal hydraulic press... You get a smooth very professional crimp.. If you don't have a press, you can use a good vise.. I build all my battery cables now.... Here is a shot of some of the crimps...
Exposed is offline   Reply With Quote
Old 03-18-2009, 08:24 AM   #21
whittlecj
1980 CJ7
West Marine is way too expensive!!!
OK, I have a press so I might get one of the hammer crimpers and go after it. I did find alot of variance on cable - Airgas has a 4 welding wire 25' for 23$ or so. Would this be ok?
Old 03-18-2009, 08:33 AM   #22
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Originally Posted by GPER View Post
The new cables I made for my winch, I never crimped the connections. I used a propane torch and just soldered the end on good. Any problem with that?????
When doing a long hard haul like pulling a dead truck hulk out of a ravine to the trail on an area clean up, I managed to get the ends of my winch cable hot enough to blow the heat shrink off them. This would have melted solder I bet, it was just smoking hot.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 03-18-2009, 08:38 AM   #23
IBGRMPY
Jeep Hammer
First let me say I like your write ups, very easy to follow.
When I first bought my jeep, I did not want a "normal" battery cable as they corrode way to easy and the cables are not protected.
What I did was buy a set of cables with factory crimp eyelets on both sides then purchased marine terminals with a wing nut connection.
Would you see anything negative about this set up?
Thanks
http://s613.photobucket.com/albums/tt215/ibgrumpy_renegade/Original%20Jeep%20Photos/?action=view&current=DSC_0007.jpg
IBGRMPY is offline   Reply With Quote
Old 03-18-2009, 09:25 AM   #24
kickingprop
No FunHaters Allowed!
kickingprop's Avatar
Originally Posted by JeepHammer View Post
PARTS, Consumables.
AND,
JeepHammer do you have any parts #'s for these by any chance? I'm making a run to Fastenal friday for a few other things and figured I might as well knock this project out while I'm at it. I guess I could not be a lazya$$ and find them myself but I thought you might have the p/n handy
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline   Reply With Quote
Old 03-18-2009, 10:53 AM   #25
JeepHammer
Running On Empty...
1973 CJ5
Would be about perfect if it's got the rubberized insulation on it.
Old 03-18-2009, 10:56 AM   #26
JeepHammer
Running On Empty...
1973 CJ5
Part numbers will depend on the wire size you intend to use,
So a part number would be counter-productive since I don't know what size cables you all are going to use...
Remember,
Two wires will fit in one terminal just as easy as one if you want to power more than one accessory!
Old 03-18-2009, 10:56 AM   #27
whittlecj
1980 CJ7
From the Airgas site: "Proven to be the standard in the industry, our Radnor® cable features a neoprene insulation which meets or exceeds all industry specifications, so it's a smart choice for every purpose"
so I guess that is good!
I would also be interested in the fastenal numbers for the terminals someone posted above - I looked through their catalog for a while and couldn't find them!
Old 03-18-2009, 10:57 AM   #28
JeepHammer
Running On Empty...
1973 CJ5
Originally Posted by IBGRMPY View Post
Jeep Hammer
Thanks
Not really...
More connections means more connection resistance, but adding ONE extra connection to the circuit shouldn't hurt much...
Old 03-18-2009, 11:01 AM   #29
whittlecj
1980 CJ7
Remember,
Any part number would be helpful so I could find the others.
Do you mean that I could buy a terminal for 1 guage (or larger) and then put in 2 4 guage wires? (one to starter, one to alternator) or something?
Old 03-18-2009, 11:16 AM   #30
kickingprop
I'd probably be going with 1ga welding cable most likely since we have a spool of it readily available at work and they could care less if I took a few feet off it. Its been a while since i set foot in fastenal but most of this stuff should be in the same general area I would imagine...
1985 CJ7 Project
Glock Forum
