M38A1 Build Thread - Page 4 - JeepForum.com
post #46 of 115 Old 08-09-2009, 10:01 PM Thread Starter
AbsolutXJ
1953 M-38
Update
Tonight the jeep finally rolled out from underneath the shop overhang and got parked in the yard. I finally have managed to bolt up the springs, axles, steering gear, hubs and drums, and mount the tires.
Flat head screws had to be drilled out in order to mount the hubs to the new drums. Everything came apart relatively easy. A couple taps on the back side of the old drums and the hubs popped right out.
Hubs mounted up
This is the last picture of the evening. Got too dark to take pictures of the rolling chasis. I'll have some up on Tuesday when I have a day off
The drums came from Kaiser Willys. I've been fairly happy with the stuff I've ordered so far. The springs and shackles didnt mount up as easilty as I would have been led to believe. I think i have a bent mounting bracket which is contributing to the problems.
Plans for the next couple of weeks:
-Finish putting the steering gear back together and rebuild the steering wheel pieces and parts
-Finish tearing down the motor and get it to the machine shop to see what the damage to the cylinder wall is
-Open up the transmission and transfer case and rebuild both
-Reinstall motor, trans, and transfer case
1979 CJ-7
1978 CJ-5 (Wrecked Awaiting Rebuild)
Willys M38A1 - project vehicle
AbsolutXJ is offline
post #47 of 115 Old 02-06-2010, 01:32 PM Thread Starter
AbsolutXJ
1953 M-38
Beat back 18" of snow today and got in the shop. Transmission and all is torn down. Starting to sand, inspect, paint, etc...
1979 CJ-7
post #48 of 115 Old 04-05-2010, 12:38 PM
BRad704
Nothing to see here...
BRad704's Avatar
I'm diggin this thread up from 2 months ago out of my curiosity with your project, and that I have my eye on a '53 M38A1 that looks to be in restorable shape. Just trying to convince my wife... $600, and I'll offer $450.
BRad704 is offline
post #49 of 115 Old 01-11-2011, 06:25 PM Thread Starter
AbsolutXJ
1953 M-38
Digging Into the Transmission
Getting back to this Jeep and Jeepforum after moving houses. I now have a shop where the Jeep can be worked on indoors and everything can be tracked a little bit better.
Couple pictures of the new (to me) shop
I decided to do a complete rebuild of the T90 transmission even though it on has 25k miles on it. This is mainly because the Jeep sat for nearly 10 years without being driven. After pulling everything out of the case, everything looks pretty decent although covered in a nice layer of old grease and crud.
Second Speed Gear was badly pitted with rust. Old on the left with a replacement from Quadratec on the right.
1979 CJ-7
post #50 of 115 Old 01-11-2011, 06:35 PM
CACooper
Subscribed!
Thread Link:
Originally Posted by Nuthin
...I have tentatively decided I actually enjoy this Cooper-person. Deal with it.
Originally Posted by -Zona-
For some reason I keep underestimating you.
CACooper is offline
post #51 of 115 Old 01-11-2011, 06:37 PM Thread Starter
AbsolutXJ
1953 M-38
All needle bearings and spacer washers were replaced in the countershaft. After reading numerous articles online about loading these bearings, I decided to use a piece of 3/4"x7" wooden dowel rod. By inserting this through the countershaft and coating each needle bearing with a little bit of chassis grease, everything went together perfectly.
Last row of needle bearings loaded
Countershaft gear loaded in the bottom of the transmission
1979 CJ-7
post #52 of 115 Old 01-11-2011, 11:29 PM
Skerr
Congrats on the new house and great shop! That's gotta make you feel very good. Glad I found your thread! Keep up the good work.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #53 of 115 Old 01-12-2011, 06:40 AM Thread Starter
AbsolutXJ
1953 M-38
Hey thanks! Hopefully I'll do a better job at keeping updated from now on. Lots more of this project to come for sure.
1979 CJ-7
post #54 of 115 Old 01-12-2011, 07:36 AM Thread Starter
AbsolutXJ
1953 M-38
Stamps?
Wondering if anyone has any insight into the significance of the numbers stamped into the gasket facing on the top of the T90 transmission housing
1979 CJ-7
post #55 of 115 Old 01-12-2011, 12:28 PM
243
1978 FSJ Cherokee
I don't know how I missed this build thread, great job
Dave's 78 Build
243 is offline
post #56 of 115 Old 01-12-2011, 03:48 PM
yippie21
1979 CJ7
Secret Code ( that's why it's stamped with an S ) If you had the willy's code book, the numbers would mean something...
PS: Awesome garage there... color me insanely jealous. Great project... good luck!
'79 CJ7
'09 JK Unlimited Sahara ( sold )
'97 TJ (sold )
yippie21 is offline
post #57 of 115 Old 01-12-2011, 07:25 PM Thread Starter
AbsolutXJ
1953 M-38
Haha...I figured it was something like that. Next project...eat my box of cheerios and send off for the secret decoder ring...
1979 CJ-7
post #58 of 115 Old 01-12-2011, 07:48 PM
lanecj5
1980 CJ5
WOW...I am keeping up with this one.Lookin great.
lanecj5 is offline
post #59 of 115 Old 01-12-2011, 08:20 PM Thread Starter
AbsolutXJ
1953 M-38
Sorry for harping on the transmission rebuild so much. This is my first run at digging into a rebuild of this magnitude so I want to make sure I'm running down the right road so to speak.
Whoever invented these snap rings without holes or tabs should have bad things happen to them...after ruining a pair of needle nose pliers on the bench grinder and wasting an hour, I finally managed to muscle the ring onto the end of the main shaft...
Loading the clutch gear proved to be a little bit of a learning curve but was easy once I got the hang of it. Noticed the synchronizer blocks located at 4,7, and 12. The springs located on either side of the gear hold the blocks in place and then the sliding gear is put in place around the clutch gear.
Two pictures of the final gear set ready to be loaded into the case. Project for tomorrow night perhaps.
1979 CJ-7
post #60 of 115 Old 01-12-2011, 08:23 PM Thread Starter
AbsolutXJ
1953 M-38
1979 CJ-7
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
1979 CJ7 Build Thread danheit Jeep CJ Forum 113 02-23-2010 10:20 PM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 11:47 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
