M.O.R.E. Bombproof motor mount - JeepForum.com
post #1 of 5 Old 10-22-2009, 08:29 PM Thread Starter
Roadymi
1982 CJ7
I installed these for the 360 I am installing in my CJ7.
For anyone that has done this I have a question. Did you use all 6 factory mounting holes to the frame? I have my tub off and it seems awful far back. I'm afraid I'm going to be into my firewall. Also did you need any body lift to clear the tranny and TC? If so how much?
While we are in the vicinity, I have the rear dump exhaust manifolds. Is this going to be an issue for my clutch linkage? Seems like I've read some have had to go to center dumps from a 304.
Roadymi is offline
post #2 of 5 Old 10-22-2009, 08:42 PM
John N
1981 CJ8
I used 5 bolts on each side. It cleared with out a body lift, but was close. I have since added a 1" Daystar body lift, but not because of the engine or trans clearance.
I think you will have to get a center dump manifold for the left side.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 5 Old 10-23-2009, 08:24 AM
CSP
Never had any problems with mine being close to the tub. Make sure that you don't have the sides swapped. It's easy to do.
Look through the holes in the frame and you'll notice that not all of them have a tubular sleeve in them. Use the ones that are sleeved (there are four IIRC).
CSP is offline
post #4 of 5 Old 10-23-2009, 08:53 PM Thread Starter
Roadymi
1982 CJ7
According to how I read the directions, I mounted the one with the dogleg on the drivers side. Is this correct?
Roadymi is offline
post #5 of 5 Old 10-23-2009, 11:52 PM
CJ5Doc
1975 CJ5
Yes dog leg on the driver side..... I used all 6 bolts on mine.... and no clearance problems
http://i697.photobucket.com/albums/v...66/Amc4013.jpg
CJ5Doc is offline
MORE Bombproof V8 Motor Mounts Hybrid Jeep Jeep CJ Forum 17 02-10-2009 01:34 PM
bombproof motor mounts Highlandjeep Jeep CJ Forum 5 01-21-2008 06:19 PM
More Bombproof mounts 360 CJ5 atom73 Jeep CJ Forum 2 11-17-2007 02:08 PM
M.O.R.E. Bombproof Motor Mounts, for a 4 Cyl? Aphelion79 Jeep CJ Forum 6 07-08-2006 09:48 PM
Bombproof vs Poly vs Ruber Motor mounts junglejeep Jeep CJ Forum 5 01-21-2004 06:53 PM
